It is currently Fri Apr 19, 2024 3:28 pm
[ 8 posts ] |
Modded big block GD longtail
Russ
So, just slapped my modded briggs power head on a godevil longtail frame to have something to hunt with after selling my old gtr frame while I continue plugging along on my next project. It's a piston/rod motor with most of the fixins, and a stock muffler right now.
Just ran it today, results follow. MM Brand: Godevil Longtail Horsepower: roughly stage 3 with stock muffler Boat Brand: Prodigy Boat Size: 1748 Boat Layout: open, with gunbox
Speeds | Shallow Water: no testing yet Speeds | Deep Water: 19mph with and against current Total Boat Load With Gear Etc: 4 people, all the standard hunt gear plus a dozen or 2 dozen decoys.
Speeds | Shallow Water: no testing Speeds | Deep Water: 26 mph against current, 28 with. Total Boat Load With Gear Etc: 1 person, all hunt gear still from 4 people.
Conditions Tested In: Bayou had current, noted on speeds. Negligible wind. 48 degrees. Carb needs a little jet work, prop is a worn 9x8. Will add notes when new props tested and carb tuned correctly and other loads tested.
Comments: Hops out of hole pretty well solo with the gear, gets going quickly with 4 just doesn't really hop out of the water until around 17. It's not a lot of boat lift for that kind of load. A new prop (10x8 or maybe 10x7 with some cup added) should help that some. Tach battery was mostly dead yesterday, forgot to pick up another. Really need to see what kind of rpms I'm turning to get the propping right. Pretty sure when I opened it up under load im all over 4700 or more. Feeling the slip solo and under load, I think there's a good bit more to be had loaded and solo than what I saw today as far as being able to plane out a little slower and pick up a bit of speed loaded (I'm not trying to run 30).
Fri Nov 23, 2018 8:19 pm |
Russ
Re: Modded big block GD longtail
With 3 and 5 dozen decoys plus normal hunting gear today ran 23 steady, hopped out of the hole nicely.
Sat Nov 24, 2018 12:58 pm |
Will C
Sounds like fun, on to next project
Mon Nov 26, 2018 8:36 am |
WI715
Did you pick the prodigy hull up new or used?
Sent from my SM-G950U using Tapatalk
_________________ Extreme Metal Fab 16x48 w/huntdeck 40EFI Backwater LT
Fri Feb 01, 2019 9:48 am |
lastchance
Joined: Wed Feb 09, 2011 1:56 pm Posts: 1646 Location: Chauvin
That's impressive speeds!! My 31hp godevil lt would run 13 with 2 adults and a kid! [FLUSHED FACE]
Sent from my SAMSUNG-SM-G935A using Tapatalk
Fri Feb 01, 2019 10:43 am |
Russ
Fri Feb 01, 2019 10:53 am |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
Stage 3? Sounds like a time bomb....... tick tick lol
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
Sat Feb 02, 2019 4:16 am |
WI715
Sun Feb 03, 2019 8:02 am |
[ 8 posts ] |
Users browsing this forum: No registered users and 222 guests |
