It is currently Fri Jun 20, 2025 6:30 pm
Reply to topic  [ 10 posts ]
 36 PD Stock - 16 x 48 Alweld
Post 36 PD Stock - 16 x 48 Alweld
MM Brand: Pro-Drive
Horsepower: 36 HP Stock FPR PT&T
Boat Brand: AlWeld
Boat Size: 16 x 48
Boat Layout: Single Seat – No Flotation
Speeds | Shallow Water: 29.7 New – 1 year later 26.7
Speeds | Deep Water: 28 New – 1 year later 26.7
Total Boat Load With Gear Etc: One Person, 6 gallons gas
Conditions Tested In: 50 degree temp, flat water
Comments: Been having it for about 1 year now, no complaints except for lost of speed. Whenever I contacted KP at ProDrive, he has been very helpful. Use it for Duck hunting, drop net crabbing, & Fishing. Duck Hunted in water deep enough to float the decoys, when we parked the boat to hunt, we were not floating and had no problems with shallow water. Ran a mud boat for 30 years, the MM configuration gives you so much more room. Would suggest a MM over a mud boat to anyone ready to buy.
16 x 48 Alweld - 36 PD FPR PT&T
Thu Dec 10, 2009 12:05 pm
Post Re: 36 PD Stock - 16 x 48 Alweld
Nice rig 8-)
Pro Drive m'fers
Thu Dec 10, 2009 12:14 pm
Nice Clean Rig you're running.
:mrgreen:
1652 w/ MB Mini 35
Thu Dec 10, 2009 12:37 pm
looks good man, nice and clean... go get it bloody or muddy! :mrgreen:
ETD88 09/28/09-05/14/2010...
Thu Dec 10, 2009 1:02 pm
Nice boat..... My guess is your loss of speed is a result of a worn out prop. What rpms you running?
WC Custom 1854
Sat Dec 12, 2009 7:20 pm
Thanks everyone for the reply's
Tested the governor, 4150
The prop is not worn, running 3910 trimmed to best speed. If I trim up higher, gain RPM - loose speed.
The bottom looks OK, but the transom has about a 3/8" dip in it at the engine.
Sun Dec 13, 2009 9:48 am
Sun Dec 13, 2009 9:28 pm
Out of water RPM's should be more around 4350 in neutral warmed up, turn the motor up some. A hook in the hull will cost you speed. Any hooks along the cross ribs? Most likely the hook is you main issue.
PW
Paul V. Willging - Owner
Phowler Boat Company
Illowa Marine
1701 Main Avenue, Clinton, Iowa 52732
563-242-8969 or cell 563-212-7091
email: larrys-prodrive@mchsi.com
http://www.larrysillowamarine.com
Mon Dec 14, 2009 3:55 pm
someone explain to me what a hook is?
Sun Jan 17, 2010 6:37 pm
18x48 Charles Leonard / 36PD
Sun Jan 17, 2010 6:42 pm
Users browsing this forum: No registered users and 67 guests
