It is currently Fri Jun 20, 2025 1:51 pm
Reply to topic  [ 14 posts ]
 prodrive 1748/ 36 LS hydraulic trim
Post prodrive 1748/ 36 LS hydraulic trim
Well, went ahead and bought another boat. Picked up a prodrive 1748 w/ tall transom, pointed bow, extended deck, and thats about it for the extras. The motor is a prodrive 36 w/ hydraulic trim, FPR, and the long shaft.
Some obvious diffrences between this boat and my old one (gator trax 3-man hide w/ MB 35 stage 3) are the hide was much more stable and the hide cornered better at high speeds. I also liked the throttle set-up better on my MB. The main reason for my switch was I run alot of tight tember at idle and needed reverse. Well, this 1748 w/ pointed bow is great in the tember, handles much better at idle and at the ramp. The FPR is great when i had to use it several times in some tight creeks, beats gettin the push pole out when theres no room to turn around. Boat plains w/ alot less throttle too.
All in all, i gave up some stability and big water capabilities but gained in the areas i use the boat the most, i'm happy with the switch. Not to mention i see close to the same speeds w/ the stock PD 36 as i was w/ the modded MB 35 (much lighter boat).
Load: me (200lbs), standard gear (push pole, fire extinguisher, tool bag, full tank of fuel, bat ext.)
Deep water: 28.5-29.5 (mild chop)
Shallow water: 31.5 (steady)
i'll update after some mods..........
Fri Mar 26, 2010 4:40 pm
Post Re: prodrive 1748/ 36 LS hydraulic trim
Congrats on your purchase. Those are pretty good speeds.
WC Custom 1854
Fri Mar 26, 2010 5:30 pm
thats what i was thinking, wonder what will happen w/ some prop wear?! thanks
Fri Mar 26, 2010 5:32 pm
Nice lookin boat! Congrats.
My motor doesn't have docking assistance, it has REVERSE!
Sat Apr 03, 2010 10:37 am
dang where'd you stick that gar shadow?
Sat Apr 03, 2010 5:40 pm
nice boat wes, thats movin btw
Sun Apr 04, 2010 2:33 am
Hey Wes, where were those pics taken?
Woody
17x54 Gator-Tail w/ 35HP GTR
Gator-tail/MM exhaust
Center Console...it fixes tiller torque
viewtopic.php?f=4&t=9330
Mon Apr 05, 2010 6:55 am
Mon Apr 05, 2010 10:25 am
Mon Apr 05, 2010 10:33 am
I thought that looked like the Nav channel...didn't know you could go out 71st and put in...i've always put in off of 412 or down at Afton Landing.
Woody
Mon Apr 05, 2010 12:34 pm
thats a very nice boat man. congrats
ETD88 09/28/09-05/14/2010...
Mon Apr 05, 2010 12:39 pm
thanks etd, and woody yes sir just ride out 71st e till you hit gravel almost to the channel you'll see a sign for the landing turn left and follow it down to the park, if ya hit the lock/ river you gone to far....... go back and find the turn off for the park/ ramp
Mon Apr 05, 2010 12:47 pm
I like the new rig...looks really good...
Question for you and Jamie:
I live at hwy75/71st street...where is the closest body of water that i can put my rig in and take my girls fishing?
Thanks,
Woody
Mon Apr 05, 2010 1:11 pm
If you asked me I'd say Lake Sahoma, just outside of Sapalupa; small, safe, and good fishing. Make sure you have your license and permits, if your kids are under 16 you should be fine, but check the reg's.
Mon Apr 05, 2010 1:29 pm
Users browsing this forum: No registered users and 83 guests
