prodrive 1748/ 36 LS hydraulic trim
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=8677
Author:  WES [ Fri Mar 26, 2010 4:40 pm ]
Post subject:  prodrive 1748/ 36 LS hydraulic trim
Well, went ahead and bought another boat. Picked up a prodrive 1748 w/ tall transom, pointed bow, extended deck, and thats about it for the extras. The motor is a prodrive 36 w/ hydraulic trim, FPR, and the long shaft.
Some obvious diffrences between this boat and my old one (gator trax 3-man hide w/ MB 35 stage 3) are the hide was much more stable and the hide cornered better at high speeds. I also liked the throttle set-up better on my MB. The main reason for my switch was I run alot of tight tember at idle and needed reverse. Well, this 1748 w/ pointed bow is great in the tember, handles much better at idle and at the ramp. The FPR is great when i had to use it several times in some tight creeks, beats gettin the push pole out when theres no room to turn around. Boat plains w/ alot less throttle too.
All in all, i gave up some stability and big water capabilities but gained in the areas i use the boat the most, i'm happy with the switch. Not to mention i see close to the same speeds w/ the stock PD 36 as i was w/ the modded MB 35 (much lighter boat).
Load: me (200lbs), standard gear (push pole, fire extinguisher, tool bag, full tank of fuel, bat ext.)
Deep water: 28.5-29.5 (mild chop)
Shallow water: 31.5 (steady)
i'll update after some mods..........
Author:  Full Throttle [ Fri Mar 26, 2010 5:30 pm ]
Post subject:  Re: prodrive 1748/ 36 LS hydraulic trim
Congrats on your purchase. Those are pretty good speeds.
Author:  WES [ Fri Mar 26, 2010 5:32 pm ]
thats what i was thinking, wonder what will happen w/ some prop wear?! thanks
Author:  Shadow [ Sat Apr 03, 2010 10:37 am ]
Nice lookin boat! Congrats.
Author:  WES [ Sat Apr 03, 2010 5:40 pm ]
dang where'd you stick that gar shadow?
Author:  TURBODRIVE [ Sun Apr 04, 2010 2:33 am ]
nice boat wes, thats movin btw
Author:  Tulsa_Woody [ Mon Apr 05, 2010 6:55 am ]
Hey Wes, where were those pics taken?
Woody
Author:  Mitschke [ Mon Apr 05, 2010 10:25 am ]
Author:  WES [ Mon Apr 05, 2010 10:33 am ]
Author:  Tulsa_Woody [ Mon Apr 05, 2010 12:34 pm ]
I thought that looked like the Nav channel...didn't know you could go out 71st and put in...i've always put in off of 412 or down at Afton Landing.
Woody
Author:  EasTexDux88 [ Mon Apr 05, 2010 12:39 pm ]
thats a very nice boat man. congrats
Author:  WES [ Mon Apr 05, 2010 12:47 pm ]
thanks etd, and woody yes sir just ride out 71st e till you hit gravel almost to the channel you'll see a sign for the landing turn left and follow it down to the park, if ya hit the lock/ river you gone to far....... go back and find the turn off for the park/ ramp
Author:  Tulsa_Woody [ Mon Apr 05, 2010 1:11 pm ]
I like the new rig...looks really good...
Question for you and Jamie:
I live at hwy75/71st street...where is the closest body of water that i can put my rig in and take my girls fishing?
Thanks,
Woody
Author:  WES [ Mon Apr 05, 2010 1:29 pm ]
If you asked me I'd say Lake Sahoma, just outside of Sapalupa; small, safe, and good fishing. Make sure you have your license and permits, if your kids are under 16 you should be fine, but check the reg's.
