36pd on 16/48 fully customized weld-craft
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=5&t=929
Author:  bigfishlon [ Tue Mar 03, 2009 8:01 pm ]
Post subject:  36pd on 16/48 fully customized weld-craft
Just me in the boat going fishing, 14 gals, 25lbs ice, rods, and tackle i've seen 31.5 on the gps, and loaded down with 3 people and gear bout 900lbs in the boat i never run less than 27!
Author:  Brinkleydog [ Tue Mar 03, 2009 9:34 pm ]
Post subject:  Re: 36pd on 16/48 fully customized weld-craft
That's a quick rig...what is the hull thickness?
Sounds like it carries what u need at a vey good speeds.......
Lets see the pics I got a boat fetish.......
Author:  bigfishlon [ Tue Mar 03, 2009 9:40 pm ]
The stock hull weighs only 280lbs and is .125 alum. I been trying to kill it but can only manage to dent the bottom slightly. it has 8 crimps on the bottom so it does not slide at all! I will be posting some pics when i get in from offshore. Also getting lined up to put a EVT stage III on it and then we will see how it runs..
Author:  Phathead [ Thu Mar 05, 2009 8:17 pm ]
Are you talking about a stock 36? If so, I would have to see it to believe it. 31.5 unloaded is pretty salty on this style hull with a stock 36, and 27 with a 3 man load is phenomenal. Furthermore, I've never seen a .125'' 1648 that weighed that little. But hey, if you say so!
Author:  basinhunter [ Thu Mar 05, 2009 8:53 pm ]
You must have that MB gps
Author:  deltaduckmaster [ Thu Mar 05, 2009 9:36 pm ]
Author:  stumpgrinder [ Fri Mar 06, 2009 8:21 am ]
I have yet to see a Weld-Craft hull made of .125
Author:  aucoin [ Fri Mar 06, 2009 9:41 am ]
welded a transom on one yesterday.....them things are paper thin......i've welded plenty .100 and it seemed thinner than that prolly .090
you put a stage 3 on that boat, you will tear that transom to peices!!!!!
Author:  stumpgrinder [ Fri Mar 06, 2009 9:51 am ]
used to run one of der tunnels. I know dey offer .090 & .100, don't know of a .125
Author:  MaXXis85 [ Fri Mar 06, 2009 10:56 am ]
My Brother Breaux hull is all .125 and it weighs close to 500# or more. I call BS on a .125 hull weighing uder 300#. I know when i pull my boat compared to my Grandpaws 1544 Lowe i can tell mine is there where as his little bateau is just bouncin behind me.
Author:  Ryan190 [ Mon Mar 23, 2009 10:33 pm ]
china metal is a lot lighter, :lol:
