It is currently Sun Mar 29, 2026 4:01 am
Reply to topic  [ 10 posts ]
 Not enough power??
Post Not enough power??
Just purchased a 17X44 Gatortrax and put a 24 hp mudbuddy LT on this boat. Took the boat out yesterday and the boat did not run well at all. My trolling motor push the boat about as fast as the mudbuddy did. Max speed was about 8 mph. The motor seemed to be running fine out of the water but in the water opened up all the way it sounded like it was choking out. It made me think the boat was to heavy for this motor. What are some ideas of what the problem could be?
Mon Aug 02, 2010 12:47 pm
Post Re: Not enough power??
That size motor should push that boat mid-high teens easy. What is the transom height and angle?
Mon Aug 02, 2010 1:01 pm
I believe the transom height is 18 inches (measured from the inside of the boat).
Mon Aug 02, 2010 2:51 pm
Transom height for a LT should be close to 15" I believe.
Mon Aug 02, 2010 3:06 pm
It measures at 15" from the outside of the boat.
Mon Aug 02, 2010 3:30 pm
sounds like a carb or misfire it shouldnt almost choke it out
Mon Aug 02, 2010 9:28 pm
is that a 24 honda?
Mon Aug 02, 2010 11:03 pm
Is the motor new or used...
Tue Aug 03, 2010 6:14 am
Check carb. My buddy has a 35 gdsd and did the same thing.
Tue Aug 03, 2010 3:46 pm
The motor is a used honda.
Tue Aug 03, 2010 6:41 pm
