godevil16
 what causes this
16hp briggs to spit and sputter wen u get on it?
| Thu Oct 07, 2010 6:35 pm |
Tenpoint
Joined: Thu Aug 27, 2009 5:22 pm Posts: 2029 Location: Patterson LA
 Re: what causes this
bad gas. dirty carb maybe
_________________ 19x48 Rink/Aucoin Bateau w/35 GTR 20x60 Home-made skiff w/200 Merc
| Thu Oct 07, 2010 6:36 pm |
mississippiduckboy
dirty carb my guess
_________________ 14 by 44 Weld Craft powered by a 20hp. go devil longtail Team Arc Angel Bowfishing
| Thu Oct 07, 2010 6:37 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
needs carb cleaned. not just wit spray, totally disassembled and cleaned thoroughly
godevil16
wat would it cost at a lawnmower shop to do it bc i have no clue hom to mess with that
| Thu Oct 07, 2010 6:40 pm |
autogateman
the one where i live (gonzales la) is 45 an hour
| Thu Oct 07, 2010 6:44 pm |
godevil16
dam i juss dont trust maself taking it apart and putting it back together
| Thu Oct 07, 2010 6:45 pm |
autogateman
the dissasembly/assembly part is actually very easy. its making sure the air/fuel mixture screw is set correctly and then adjusting proper idle speed.
| Thu Oct 07, 2010 6:47 pm |
godevil16
do u do that whie the carb is on or off? the adjusting
| Thu Oct 07, 2010 6:50 pm |
autogateman
with the fuel mixture screw, after you remove the carb, tighten and LIGHTLY seat the screw, while counting how many turns it took to get there. when you reassemble, put the screw all the way back in, then back it out to where it was before. and you do that off of the boat, you shouldnt have to mess wit it after reinstalling the carb if you got it right. the idle screw can actually prolly be left in place. the main thing is that you wanna remove the jets, o rings and gaskets. the orings and gaskets will be ate up from the cleaner. i buy the cleaner in a gallon from oreilly auto, it has concise instructions on the label, it works great
| Thu Oct 07, 2010 6:55 pm |
godevil16
alright ill take a look at it tomorrow thanks man for all the help
| Thu Oct 07, 2010 7:17 pm |
autogateman
no prob bud. btw, i buy a service manual for everything i have that has an engine. the factory manual will explain everything in detail. any lawnmower shop can get you one
| Thu Oct 07, 2010 7:19 pm |
kibb
| Thu Oct 07, 2010 7:21 pm |
godevil16
iight ima check it out next time i go..................x2?
| Thu Oct 07, 2010 7:28 pm |
autogateman
that means i agree
| Thu Oct 07, 2010 7:30 pm |
godevil16
oh ok lol i was lost for a sec
| Thu Oct 07, 2010 7:35 pm |
