It is currently Thu Apr 02, 2026 8:08 am
Reply to topic  [ 11 posts ]
 balance?
Post balance?
Im new to mud motors. Purchased a used 16 Vanguard mud buddy a couple weeks ago. Im still dialing in the motor and learning what to do and not to do with a long tail.
I noticed that my motor is un balanced when not under power? THe weight is engine heavy to the point that it leans into the boat? SHould the tail end not be heavier?
Sat Nov 13, 2010 7:53 pm
Post Re: balance?
it outta be balanced, they make it that way so it is easy to lift the prop out the water,so the prop outta stay in the water we running it, even wen its not running it should still stay down. is there any mods to the frame that couldve effected the balance?
Running a homemade 14x38 skiff with the good ole' 13 h.p Go-Devil longtail
Sat Nov 13, 2010 7:58 pm
Post Re: balance?
I think go devil is the balanced one go devil not mud buddy.
Team Arc Angel Bowfishing
Sat Nov 13, 2010 7:59 pm
Post Re: balance?
i just looked on the mudbuddy sight and they dont have a 16 h.p vanguard engine for the longtails, maybe its a diffferent engine? i know on my Go-devil its balanced so its not engine heavy
Sat Nov 13, 2010 8:02 pm
Post Re: balance?
MB are balanced to . Well mine is. My 18 GDLT was not and that came from a GD dealer.
16X48 G3 MBLT BD4500
Sat Nov 13, 2010 8:58 pm
Post Re: balance?
Im not sure what year the mud buddy is? Or if a differnt engine has been placed on the frame? It is a 16hp vanguard. nothing looks like it has been modified on the frame?
Sitting on the trailer. tail out the back. The motor will fall down into the boat? I can tilt it down to the ground (water) and it will stay there if the water is deep. but it is engine heavy for sure. is that normal?
Sun Nov 14, 2010 5:45 pm
Post Re: balance?
tighten the nuts that hold the pivot shaft in place, just enough to where it is not hard to pick up and down. I was told that by Coco from GD
Sun Nov 14, 2010 5:47 pm
Post Re: balance?
Sun Nov 14, 2010 8:27 pm
Post Re: balance?
i use a lil gadget that injects lube into the housing, u can get it from any motorcycle or dirtbike shop.
Sun Nov 14, 2010 8:30 pm
Post Re: balance?
but instead of injecting lube shoot automotive anti freeze in there, problem solved.
Mon Nov 15, 2010 7:22 pm
Post Re: balance?
Thanks guys. I got a good tip from mud buddys web site videos. PLace a loop at each end of the cable to prevent water from running into the cable. I did that. I also used a oil made for nail guns that has a antifreeze in it. Not sure how much got down into the cable? Im going to look for the gadget as metioned above.
Mon Nov 15, 2010 7:59 pm
