tsutxn09
Joined: Mon Aug 09, 2010 9:36 pm Posts: 91 Location: Huntsville, Texas
 GDLT knocking???
hey guys went and ran the boat yesterday and had a knocking noise coming from what sounded like the end of the shaft anyone got any ideas. It almost sounds like im hitting a stick under the water every now and then???
| Fri Jan 14, 2011 9:06 pm |
kibb
Joined: Wed Jan 14, 2009 8:58 pm Posts: 2731 Location: Lafayette, LA
 Re: GDLT knocking???
Does your prop have slack in it? Iis the knocking when you lift the prop in and out the water? If this is the case there is no need to worry.
_________________ 1644 WeldCraft / 27 GDLT Ranger R71 / 125 Merc
| Fri Jan 14, 2011 9:35 pm |
tsutxn09
No the prop is floating properly this is happening while its running I redid the prop just to be sure per the GD specs. Its not the normal whiz and pop it actually feels like im hitting sticks while im running.
| Fri Jan 14, 2011 9:38 pm |
b_coonass
Joined: Thu Mar 26, 2009 2:08 pm Posts: 1229 Location: morgan city, louisiana
_________________ 36hp Pro-Drive with EVT exhaust pushin a 17x42 custom skiff
| Fri Jan 14, 2011 9:41 pm |
tsutxn09
No its not a revolution thing as far as i can tell, but there is some vibration but its always been there i dont think its anything out of the ordinary, it almost feels like the shaft is bouncing or in the bushing or something but i have no clue
| Fri Jan 14, 2011 9:46 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
Check your U-joint it may be going out and may be trying to cease up thus causing it to pop
| Fri Jan 14, 2011 10:08 pm |
tsutxn09
how do i check the u Joint b/c that was an issue i was pondering
| Fri Jan 14, 2011 10:09 pm |
take'emgator
Start the motor and half throttle it and listen for the popping noise, on the other hand grease the grease zerk on the u joint and see if that hleps make sure keeper pin is tight on the MOtor side of the shaft and make sure its tight on the shaft part going into your hoising, they maybe slipping. Try that
| Fri Jan 14, 2011 10:16 pm |
tsutxn09
ok ill try that tommorow im pretty sure that pin on the motor side is tight but ill check it tommorow what would the symptoms be if the lower bushing is worn?
| Fri Jan 14, 2011 10:19 pm |
take'emgator
You'll have excessive amounts of grease coming out and if you grab the prop and you can move it up and down it has play in it
| Fri Jan 14, 2011 11:13 pm |
DeathMetalDukk
Joined: Sat Jun 27, 2009 11:50 pm Posts: 3777 Location: Knotts Island, North Carolina.
Come on Giga, jump in and save your man. The GTR owners aint looking. You would have play in your prop if your bushings were worn out.
_________________ Put yer face in the myrtles.
| Fri Jan 14, 2011 11:16 pm |
tsutxn09
I just replaced the seals on the lower end, and ive got a little bit of play on the end, but im wondering if a loose bushing could cause this knocking?
| Fri Jan 14, 2011 11:26 pm |
take'emgator
could be a bent shaft, i've had that happen before, not real sure this is interesting
| Fri Jan 14, 2011 11:39 pm |
tsutxn09
im going to pull the shaft tommorow, and see whats going on there, the weird thing is it just started doing this. Ive taken the thing out two times since i put a new prop on, and i let a buddy that i trust borrow it and he swears he didnt hit anything so i really dont think he did. i just hope its not a shaft
| Sat Jan 15, 2011 12:12 am |
take'emgator
Hey and if it is, they are cheap i mean cheap. but just go over everything that you have first and make sure everything is greased!
| Sat Jan 15, 2011 12:16 am |
tsutxn09
Hey guys, thanks for all the help ill let ya know what i come up with tommorow
| Sat Jan 15, 2011 12:42 am |
dog walker
Joined: Tue Jan 13, 2009 6:08 pm Posts: 5282 Location: Meraux,La.
I've seen longtails knock if they needed grease in the shaft log
| Sat Jan 15, 2011 6:25 pm |
tsutxn09
Guys between the rain and honey do's i didnt even get to check anything out hopefully i can get to it tommorow
| Sat Jan 15, 2011 7:24 pm |
take'emgator
take your time and don't get in a rush, do it right the first time
| Sun Jan 16, 2011 1:22 am |
tsutxn09
well guys i think ive come to my conclusion, i think the end of the shaft is bent it looks out of balance while its running. So i guess ill order the shaft and bushing tommorow, any tips or tricks or advice on the removal of the shaft.
| Mon Jan 17, 2011 7:05 pm |
take'emgator
Easiest way i found was to remove the motor and tap it out with a hammer and block of wood
| Tue Jan 18, 2011 6:14 am |
