gooseman
 lt wants to dive deep when running at all speeds
is it normal for a long tail to dive in the water or shold it sorta flot when running. I never had one befor i just ran it today for the first time and want some advice on to run on. Any advice wood be sooo grate
| Sun Apr 10, 2011 11:26 am |
Woodiebuster
 Re: lt wants to dive deep when running at all speeds
The cav. Plate should hold steady at an inch or two below the water.
| Sun Apr 10, 2011 12:07 pm |
atlong
Joined: Tue Dec 21, 2010 4:32 pm Posts: 94 Location: Starkville, MS
ive ran my new on the past two weekend and in deep water it wanting to go down deep when not a high rpms but when you get to WOT it jumps up to the top of the water. every now and then it wants to pop out the water at WOT, that means i need to bend the cav plate down a lil bit right?
_________________ Don't Tread on Me
| Sun Apr 10, 2011 8:00 pm |
brianb
Joined: Mon Nov 29, 2010 6:02 pm Posts: 534 Location: louisiana
adjust the trim tab on the cavitation plate until you find the sweet spot for your particular setup, we had one that we ran with the trim tab almost level to make it run right, on another we had to bend it down slightly to about a 30 degree angle or so, you also may need to adjust your bolt that is under the pivot plate so it does not go quite as deep in the water
_________________ gtr35 gt 1854 / w gatorglide 12 ft 11hp longtail 14 ft 10 hp longtail Merc 225hp TR20
| Sun Apr 10, 2011 8:04 pm |
kibb
Joined: Wed Jan 14, 2009 8:58 pm Posts: 2731 Location: Lafayette, LA
_________________ 1644 WeldCraft / 27 GDLT Ranger R71 / 125 Merc
| Sun Apr 10, 2011 8:13 pm |
atlong
ight thanks kibb and i just put a crescent wrench on the plate and bend it a lil bit?
| Sun Apr 10, 2011 8:33 pm |
rob_rides_03
Joined: Tue Oct 13, 2009 3:31 pm Posts: 202 Location: NJ
mine does the exact same thing. dives deep then jumps out of the water at wide open. guess i'll have to tweak it too
| Tue Apr 12, 2011 9:40 am |
marsh maniac
| Tue Apr 12, 2011 6:38 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
That's right. That bolt only should be stopping it from going too far down when you're stopped.
sent using tapatalk while smoking a cigarette, messing with the radio, and texting while driving all at once.
| Tue Apr 12, 2011 7:02 pm |
