It is currently Thu Apr 02, 2026 6:20 am
[ 7 posts ] |
montrose trapper
 Dry Bushings
So i went into my local parts store to order the bearings for my project motor that im building. The guys said that he has dry bushings in stock that should work. They go in a manual transmission but fit the 3/4 drive shaft. What are your thoughts on these has anyone used them or is it just a waste of time? If these bushings are a no go should i go with sealed bearings? I should include im building a 16 hp longtail with the duromax motor. Thanks, Bobby
| Fri Aug 12, 2011 4:26 pm |
specgoos1222
Joined: Tue Oct 19, 2010 7:02 pm Posts: 46 Location: Great Bend, KS
 Re: Dry Bushings
I would guess he was referring to bronze bushings. Thats what I used on mine. They were only like three bucks a piece.
| Fri Aug 12, 2011 6:52 pm |
fishon!!
Joined: Tue Nov 17, 2009 6:52 pm Posts: 339 Location: Capital Shity, LA
 Re: Dry Bushings
bronze bushings still need to be greased.. atleast on something moving as fast and as much as that shaft
_________________ Save your confederate money, cause the south WILL rise again homebuilt 11 HP greyhound LongTail -1436 flatbottom
| Fri Aug 12, 2011 8:12 pm |
scotts98rt
 Re: Dry Bushings
local hardware store also.
| Sat Aug 13, 2011 12:44 am |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
 Re: Dry Bushings
yea make a spacer and have it pressed in your housing then find a local supply of flange bushings. repace as needed. i found some at ace hardware.
| Sat Aug 13, 2011 6:06 am |
montrose trapper
 Re: Dry Bushings
specgoos, did you have to put a grease insert on it or did you just run them dry?
| Sat Aug 13, 2011 11:08 am |
specgoos1222
 Re: Dry Bushings
On my top bearing I have a sealed 1 5/8 X 3/4 sealed bearing in a housing. In the middle I have a 2 inch bronze bushing that I am able to grease, whether its needed or not I dont know. The bottom one I have never greased and doesnt get hot when ran in or out of water, you got to think if its in the water its not going to get all that hot.
| Sat Aug 13, 2011 12:38 pm |
[ 7 posts ] |
