It is currently Sun Mar 29, 2026 2:56 pm
[ 8 posts ] |
23hp MBLT 9x5 on 1648-15mph?!?
lftdjeep426
Joined: Mon Dec 13, 2010 2:15 pm Posts: 37 Location: Ft. Pierce, FL
Just got it hooked up and with me, two batteries, full wood front deck, 5gal of gas, trolling motor and me (190 lbs) got 15mph.
Is this good? It didn't sound like the motor really revved up like I thought it should compared to my old 13hp MBLT.
Your thoughts?
_________________ 1648 Lundau W/ MudBuddy 23hp LT(Work in Progress)
| Sat Aug 13, 2011 8:47 pm |
Woodiebuster
 Re: 23hp MBLT 9x5 on 1648-15mph?!?
Is your boat beat up on the bottom?
Prop worn?
| Sat Aug 13, 2011 9:20 pm |
cb5331
Do you have a tach? If not, get one!
| Sat Aug 13, 2011 9:25 pm |
lftdjeep426
Prop is a fairly new MB 9x5, boat is smooth with frog spit (same as steelflex) coating on bottom and smooth. Motor turns 2990rpm's. Throttle is wide open and the cable is tight and it pulls the throttle flap to lock..... Drive shaft isn't bound up.... Got a good bit of weight in the boat but with that prop, it should rev out.
| Sat Aug 20, 2011 12:26 pm |
acs7671
Joined: Sat Aug 20, 2011 5:59 pm Posts: 96 Location: Lafayette, LA
I'm no expert, but that sounds like a reasonable speed for that setup.
| Mon Aug 22, 2011 7:53 pm |
QuackStacker5253
Joined: Thu Jul 28, 2011 6:47 am Posts: 281 Location: Longview/Tyler Tx
I agree that doesnt sound like to bad of a speed depending on how heavy your boat is... Ive got the same motor and with a couple guys in my boat we get around 15
_________________ 1748 WC Custom 27 mini
| Wed Aug 24, 2011 8:20 pm |
SuperDave4x4
Joined: Fri Feb 11, 2011 8:56 pm Posts: 176 Location: Kenner, La.
_________________ 15' RiverHawk with a 23hp longtail.
Looking for a 1642 boat. PM if u have one
| Fri Aug 26, 2011 6:44 am |
Snowbird
Joined: Sat Aug 08, 2009 12:44 am Posts: 91 Location: Salt Lake City, Ut 84121
_________________ 23 MB mini w/ IM heads, BPS rockers/rods and gutted exhaust on a rivited 1648 crestliner.
| Fri Aug 26, 2011 1:57 pm |
[ 8 posts ] |
