It is currently Tue Mar 31, 2026 6:54 am
Reply to topic  [ 4 posts ]
 Squeaking at prop
Post Squeaking at prop
I have a 16 hp go devil lt that I just bought this summer. Never had a chance to do much more than crank it up since I bought it. Finally got it on a boat and was just out getting it running after it hasn't started in a couple months. It's squeaking from the prop. I don't remember it doing that before. Is that normal? I greased it per the manuals instructions before running it. Seems like it lessens or goes away all together at higher rpms.
Sun Oct 23, 2011 11:44 am
Post Re: Squeaking at prop
Sounds like it's noise would be coming from the seals near the prop I just remove the shaft from 23hp the shaft was groved at the seal area
Thu Oct 27, 2011 9:59 am
could be the scraper seal. its a hard plastic.
17*38 Klibert 23GDLT
Thu Oct 27, 2011 1:20 pm
I had the same thing.
The nice folks at GD told me this:
SPRAY WD 40 AT SHAFT AND LOWER SEALS
FLANGE BUSHING MAYBE VIBRATING
Sure enough, that stopped it.
Tue Nov 08, 2011 8:44 pm
