It is currently Mon Apr 06, 2026 8:29 pm
Reply to topic  [ 5 posts ]
 23 vanguard rpms?
Post 23 vanguard rpms?
i am curious as to what my 23 go devil should be putting out as far as rpms? right now with 2 people in my 14' xpress it is normally around 3570 at top speed. this seems a bit low to me but the motor runs fine and has never had an issue. any quick ways to get more rpms out of a motor like mine?
Mon Nov 07, 2011 6:55 am
Post Re: 23 vanguard rpms?
I am almost sure there are many posts on this subject-use the seach function. I am also relatively new to here but you can gain rpm's by adjusting the throttle. I have set my 27 Kohler longtail motor to 4150 rpms out of the water; this translates to around 3800 in the water under load. If you are getting 3570 in the water under load this is not too far from max. I know some are skeptical but I have noticed better performance after using synthetic oil and grease. Must be a reason the mfg.'s recommend synthetic after initial motor break in.
Mon Nov 07, 2011 10:31 am
sounds normal.
Mon Nov 07, 2011 5:38 pm
thanks for the info guys
Mon Nov 07, 2011 9:22 pm
you can adjust your governer spring and pick up a little more. i tweeked mine and ported the intake and i get 4100 out the water and 3850 two guys, dog, and hunting gear in the water wot.
23HP GO-DEVIL longtail pushing a 1750 Mike Kliebert custom
Fri Nov 11, 2011 3:07 pm
