It is currently Fri Apr 10, 2026 12:59 am
Reply to topic  [ 10 posts ]
 SUper Fast 18hp Long Tail
Post SUper Fast 18hp Long Tail
I have a 18GDLT. I bought it used and it doesn't have a rpm's gauge. the muffler glows red hot when I run it wide open. I called go devil and they said its normal. the said that motor should run about 15. I put it on the GPS and I am running 17 with two people. Stock prop. I think I might be running more rpms than I am supposed to be. What do you guys think?
Wed Nov 23, 2011 3:28 am
Post Re: SUper Fast 18hp Long Tail
What size boat do you have it on
Wed Nov 23, 2011 8:13 am
It is on a 1548 Alweld.
Wed Nov 23, 2011 6:32 pm
I run 18 with two people on a 14 by 36 with brand new prop and a 20 hp. motor.
14 by 44 Weld Craft powered by a 20hp. go devil longtail
Team Arc Angel Bowfishing
Wed Nov 23, 2011 7:32 pm
the title of this thread cracks me up.
Wed Nov 23, 2011 7:33 pm
Your getting good speeds, dont change anything, and dont expect to get any faster.
Wed Nov 23, 2011 7:47 pm
I dont think you guys are understanding what I am asking. I want to know, since I dont know how many rpms I am running if it is safe to just run my motor wide open. I believe this is an after market throttle. Is it ok to just open her up and let her run like that. I mean the muffler glows so red I could use it as an anchor light.
Sun Nov 27, 2011 4:24 pm
Buy a tiny tach to put on it. You could drastically reduce the life of your engine if you're over-revving all the time. Red hot like a light don't sound right, you could also be running very lean causing things to overheat. Get a tach first. What size prop you have on that rig?
Put yer face in the myrtles.
Sun Nov 27, 2011 4:31 pm
Mine and every other long tail i have ever seen glows red, my buddies surface drive has a blue flame about a foot long shoots out of his pipes.
Sun Nov 27, 2011 8:43 pm
Can someone post a link to one of the tachs being recommended, I beleive thats my next purchase. And post what RPM's a 25hp Kohler should max out at. And is it a simple adjustment on the high end stop where the throttle cable bolts up to the carb? Thanks - John
Mon Nov 28, 2011 6:46 am
