jedisme
Joined: Thu Feb 12, 2009 1:12 am Posts: 168 Location: Fort Walton Beach FL
 Prop loose?
Unsure how this happened, anyways noticed alot of vibration coming from the lower prop area today while hunting, eased over to a bank to further inspect and it seems my prop came loose between the nuts the prop is threaded. If this makes no sense tell me i'll snap a pic when I get home.
_________________ 16' skiff 23 GDLT
| Sat Dec 17, 2011 5:45 pm |
jedisme
 Re: Prop loose?
So my question is which end do I tighten the prop all the way then the 2 bolts down?
| Sun Dec 18, 2011 11:16 am |
Cajunwannabe
Joined: Wed Jan 28, 2009 3:40 pm Posts: 188 Location: Wishing I was in SE La.
 Re: Prop loose?
Remove the whole thing, APPLY ANTI SEIZE LIBERALLY and sandwich prop between nuts shown in picture. I put front nut on, then prop (I give mine a couple wacks with piece of 2x4 to tighten against front nut) then add the back two nuts. Mine never comes loose. DON'T FORGET ANTI SEIZE!
| Sun Dec 18, 2011 11:24 am |
brianb
Joined: Mon Nov 29, 2010 6:02 pm Posts: 534 Location: louisiana
 Re: Prop loose?
It is supposed to have about 1/2 turn slack Your vibe is probably due to your lower bushing worn and or needing grease
_________________ gtr35 gt 1854 / w gatorglide 12 ft 11hp longtail 14 ft 10 hp longtail Merc 225hp TR20
| Sun Dec 18, 2011 11:28 am |
jedisme
 Re: Prop loose?
Seems odd that this would happen guess it worked itself loose? So, I can tighten the prop up against the upper nut (hand tighten? top pic) then apply some never seez and the reinstall the nut, lock washer, locknut. Should I hand tighten the the first nut up to the prop then, torque the lock nut to it? Sorry this is such a grammatical shit storm its hell typing from a phone.
| Sun Dec 18, 2011 4:12 pm |
autogateman
Joined: Thu Sep 16, 2010 10:32 pm Posts: 4036 Location: Gonzales La
 Prop loose?
Leave enough slack in the prop so it can turn about a half turn.
| Sun Dec 18, 2011 4:34 pm |
kibb
Joined: Wed Jan 14, 2009 8:58 pm Posts: 2731 Location: Lafayette, LA
 Prop loose?
I snug my prop after applying nickel based anti-seize. Then, tighten last two nuts. Never have a problem getting them off. I've had the shaft threads get worn, from letting the prop float, causing vibration.
_________________ 1644 WeldCraft / 27 GDLT Ranger R71 / 125 Merc
| Sun Dec 18, 2011 6:04 pm |
swamprat26
 Prop loose?
I just bought a new 16 from go devil. Had to bring it back because it had too much cup. Couldnt get the RPM's above 2900. When I brought it to the back i watched them remove and install it. He tughtened the prop hand tiight and snugged the the two nuts with a lg crescent wrench. No torque wrench
| Sun Dec 18, 2011 6:08 pm |
Woodiebuster
 Re: Prop loose?
| Sun Dec 18, 2011 6:16 pm |
swamprat26
 Prop loose?
They did put a lot of nikkel ease on it
| Sun Dec 18, 2011 6:27 pm |
jedisme
 Re: Prop loose?
WTH? Who sells the anti seize? Can't find it anywhere but online.
| Sun Dec 18, 2011 7:40 pm |
swamprat26
 Prop loose?
Any napa auto zone or lowes
| Sun Dec 18, 2011 7:48 pm |
kibb
 Re: Prop loose?
Google "LPS Nickel anti-seize."
| Sun Dec 18, 2011 8:04 pm |
