It is currently Sun Apr 05, 2026 12:29 pm
Reply to topic  [ 8 posts ]
 Solid or hollow driveshaft?
Post Solid or hollow driveshaft?
Sorry for another driveshaft question. I'm working on my homemade longtail and I need to get a new driveshaft. I'm running a 1" OD shaft and that doesn't give me much clearance between it and the carrier tube.
I'd like to know, are the commercial longtails running solid or hollow drive shafts?
I see the commercial longtails have really small support tubes and obviously small diameter drive shafts. I'm wondering if they could be hollow.
My 1" OD shaft is hollow, and I'm guessing I'll go hollow on the 3/4" shaft.
Any input would be appreciated.
Greg
Thu Mar 29, 2012 4:31 pm
Post Re: Solid or hollow driveshaft?
The smaller lt's run a 3/4 solid drive shaft and the bigger ones are a 7/8. I could see a hollow drive shaft twisting under load.
Thu Mar 29, 2012 5:36 pm
Solid 3/4.......
If I can't Break it, it can't be Broke.............................
Thu Mar 29, 2012 6:27 pm
Thu Mar 29, 2012 6:31 pm
i dont think the amount of rotational force b/w the two would be great enough to beat having the added strength. go solid 3/4
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Sat Mar 31, 2012 8:52 pm
Thanks everyone!
One more question, on the commercial mudmotors, are the drive shafts supporte in the middle or just on the ends?
Greg
Sun Apr 01, 2012 2:14 am
bushings should be at top, middle and bottom of the housing.
the support for thw whole shaft and housing: you should have one long bar running from the motor to the bottom of the shaft(this supports most of the weight), two supports around the middle, and some support at the top. look at a picture and youll understand
-1436 flatbottom
Sun Apr 01, 2012 7:56 pm
Mon Apr 02, 2012 3:24 am
