It is currently Thu Apr 02, 2026 2:48 pm
Reply to topic  [ 9 posts ]
 low speed RPMs on 23 hp longtail
Post low speed RPMs on 23 hp longtail
What RPMs are yall running at idle on 23 longtail?
Thu Apr 05, 2012 5:57 pm
Post Re: low speed RPMs on 23 hp longtail
I have mine set at 1050 on my 25.
1976 16X48 Lowe powered by a 25hp MB LT and dino turds
Thu Apr 05, 2012 6:04 pm
I cannt get mine below 1500 without losing top end 3600.
Thu Apr 05, 2012 6:12 pm
Yep, that's the problem. Mine top out at 2852, which is fine with me as I like the low idle speeds.
Thu Apr 05, 2012 6:16 pm
mine idles at about 1200 out of the water and about 950-1050 in the water. top end is about 4030 out of water and 3740-3800 in the water. anything lower than 1200 out of water and it stalls when i drop the prop in the water
fiat justitia et pereat mundus
1642 WeldBilt Crawdad/ 23hp S.W.O.M.P
viewtopic.php?f=18&t=27507
viewtopic.php?f=18&t=27513
Thu Apr 05, 2012 6:25 pm
I like that RPm range. May have to do a little tinkerin with throttle
Thu Apr 05, 2012 6:29 pm
1100 idle and 4090 wot both in the water.
Sun Apr 08, 2012 7:26 pm
B. MacDonald
Mon Apr 09, 2012 6:59 am
did my tinkerin today got 1200 low end and 3850 high end. think I can live with this. Had to cut jacket on cable and cut grove in throttle stop. Think I can get a little more on hoigh end if I do little more cuttin.
Mon Apr 09, 2012 6:51 pm
