It is currently Mon Apr 06, 2026 12:43 am
[ 7 posts ] |
SouthernWake
 Need new U-joint
Where would be the best place to buy a replacement universal both local and online? I had mine shred the key and strip out the knotch in it. This is a homebuilt so no manufactureer to call on it. Thanks
| Mon Sep 03, 2012 9:30 am |
brianb
Joined: Mon Nov 29, 2010 6:02 pm Posts: 534 Location: louisiana
 Re: Need new U-joint
try driveshaftparts.com or tractor supply, just check the rpm ratings
_________________ gtr35 gt 1854 / w gatorglide 12 ft 11hp longtail 14 ft 10 hp longtail Merc 225hp TR20
| Mon Sep 03, 2012 11:27 am |
Docott
X2 tractor supply
_________________ Phil Robertson said,"It seems like, to me, a vagina -- as a man -- would be more desirable than a man's anus,"
| Mon Sep 03, 2012 12:18 pm |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
napa
| Mon Sep 03, 2012 4:39 pm |
SouthernWake
Thanks everyone, I took the old one off this morning and noticed that it stripped out the key groove on the shaft as well... I was thinking about drilling a hole through the universal and shaft and inserting a pin to hold it all together instead of using the key as this is the second time I've had one strip out. What do you guys think of this?
| Tue Sep 04, 2012 8:49 am |
Pumpgunner
Joined: Sat May 08, 2010 12:22 pm Posts: 22 Location: 15 minutes from Idaho, an hour from Wyoming
Everything I've heard says don't drill through the shaft, it will create a serious weak spot. As much as it sucks, you might have to replace your shaft.
| Thu Sep 06, 2012 12:03 pm |
Buzz Killington
B. MacDonald
| Thu Sep 06, 2012 7:13 pm |
[ 7 posts ] |
