It is currently Mon Apr 06, 2026 10:20 pm
Reply to topic  [ 11 posts ]
 Sealing top shaft
Post Sealing top shaft
Building a 16hp longtail I'm just going to use bushings
At both ends. I don't think I did a good job sealing the last longtail
I built I just sandwich the seals between two bushings.
What's another way?
Wed Jan 09, 2013 5:24 pm
Post Re: Sealing top shaft
Stack the seals on the outside of the bushings, not on the inside... stack 4 going out in out out and 2 in the top going out... The object is to keep grease around the bushings...
1436 Lowe
Wed Jan 09, 2013 6:29 pm
I did that but holding the in what I did was take a flang bushing
And sandwich them together on both ends should I have made a housing.
Thu Jan 10, 2013 10:59 am
yes
1436 Lowe
Thu Jan 10, 2013 12:13 pm
You have a pic
Thu Jan 10, 2013 12:36 pm
Search harder.... There is a wealth of info on this site and this topic has been discussed many times... larger pipe welded over the end of the shaft housing
1436 Lowe
Thu Jan 10, 2013 7:14 pm
Ya but what holds your seals in ?
Thu Jan 10, 2013 10:05 pm
some form of cap, you can thread the outside of the housing to accept a cap to hold it all in, with a hole for the shaft... I guess you could tack on a washer at the end but if you gotta replace it know youll have to buzz off them tacks and reweld a cap on when youre done
1436 Lowe
Thu Jan 10, 2013 10:23 pm
I would think you would damage your seal pushing it past the threads
Fri Jan 11, 2013 10:02 am
don;t push your seals past/over the threads turn them or screw them on like a nut.less chance of doing damage to them.
Fri Jan 11, 2013 10:43 pm
Just take some electrical tape and cover the threads.... slide on seals.... remove tape...
1436 Lowe
Sun Jan 13, 2013 1:23 am
