It is currently Fri Apr 03, 2026 5:52 pm
Reply to topic  [ 6 posts ]
 Probably a dumb question
Post Probably a dumb question
Can I braze (usin mapp) or JBWeld a steel cav plate onto an aluminum longtail?
Tue Jan 15, 2013 4:39 pm
Post Re: Probably a dumb question
No. Aluminum and steel will not mix.
Tue Jan 15, 2013 5:23 pm
You could bolt aluminum angle iron to the cavitation plate and weld it to the frame.
Tue Jan 15, 2013 6:02 pm
You might be just as well off getting a pipe repair clamp and welding the cavitation plate to that.
What kind of long tail do you have?
Quote:
Tue Jan 15, 2013 6:15 pm
It's a homemade aluminum one, and after a 45 min ride each way hunting this weekend I realized that a cav plate would make my life a lot easier.
Tue Jan 15, 2013 6:18 pm
I have a godevil 23 longtail and I can almost let go of it running down the canal. Cav plate is the way to go..
You might be able to find a two piece shaft collar to clamp around your pipe, cav plate can be welded to that.
Is your pipe aluminum? Just find a fab shop and have a aluminum plate welded to it.
Tue Jan 15, 2013 7:03 pm
