Shane77624
Joined: Thu Nov 29, 2012 6:55 am Posts: 17 Location: Nacogdoches County Texas
 Grass around the prop
The pic was taken the morning after and the grass has dried out, but you can get the jist of my question. Is this normal? I'm thinking that the gap between the upper prop nut and the seal housing is too large. Thoughts?
Sent from my Galaxy S3 using Tapatalk 2
| Fri Dec 21, 2012 11:33 am |
nasty
 Re: Grass around the prop
Looks normal to me. Keep a razor knife handy
| Fri Dec 21, 2012 11:35 am |
T-Bubba
Joined: Wed Feb 18, 2009 6:43 pm Posts: 3958 Location: Centerville, La
normal... cut it out before it gets that bad...
_________________ I gave up mud motors
| Fri Dec 21, 2012 11:38 am |
Shane77624
Okay...just wanted to check. We typically just pull into shallow water and commence to cutting. Guess we were on the right path.
Thanks for the help.
| Fri Dec 21, 2012 3:13 pm |
stualaska
Joined: Sat Jan 17, 2009 1:34 am Posts: 578 Location: North Pole, Alaska
In that ropey grass it's not unusual to get some in that area, but it does appear the clearance is excessive. Distance from the upper jam nut to the face of the seal collar should be 1/4 to 3/8 inch. Check your GoDevil manual. If you don't have one you can download it from their website.
_________________ so many rivers, so little time
| Fri Dec 21, 2012 4:24 pm |
Shane77624
I thought the space may have been a little much, but it's only about 1/4" or maybe a bit less.
Anyone seen the grass cutter made from 1/8" plate that is welded onto the skeg? I'd love to get a pic.
| Fri Dec 21, 2012 8:28 pm |
take'emgator
Joined: Mon Oct 19, 2009 6:38 pm Posts: 10201 Location: SETX
DOn't run it contiuously like that cause the grass can damage your lower seal. Its normal to get grass right there, they all do it especially when the grass is thick.
Except with my GTR i just grab the reverse and sling it off
| Fri Dec 21, 2012 11:43 pm |
brasso
_________________ 1850 Uncle J Delta Performance level 4 GTR
| Fri Dec 21, 2012 11:58 pm |
Buzz Killington
Normal
Brandon MacDonald
B. MacDonald
| Tue Jan 01, 2013 3:59 am |
ottertailriverrunner
Joined: Fri Oct 02, 2009 4:46 pm Posts: 79 Location: Otter Tail County, MN
I run through thick wild rice during the duck season and It will happen to me when I am pushing real slow at low rpm. No doubt it will slow you down.
| Tue Jan 01, 2013 8:23 pm |
swampposh
Joined: Thu Jan 17, 2013 8:39 am Posts: 13 Location: Lake Okeechobee, Kissimmee River
This site is awesome, You have answered alot of the questions I have. I have been having the same problem with bullrush getting into the space behind the prop. There is a nut between the prop and the shaft and I can't get all the grass out without removing it. I removed the front two nuts no problem but I cant get the prop to budge. Is the prop threaded? It's a BogHog motor.
_________________ Rich Aluma Weld 16' X 49" Bawg Hawg 27hp Kohler
| Thu Jan 17, 2013 12:59 pm |
