It is currently Fri Apr 03, 2026 12:15 pm
Reply to topic  [ 2 posts ]
 shaft removal on beavertail.
Post shaft removal on beavertail.
:? can any one tell me how to go about removing the shaft on my beavertail? there web sight does not have that option ....
Sat Jan 26, 2013 9:28 pm
Post Re: shaft removal on beavertail.
you will have to remove the the bolts on the universal where the shaft goes in and then then grind the small weld of the shaft.Pull your prop of remove the lower bearing housing take the bearings and seal of shaft.Make a tool to put on shaft and try to pull it out/beavertail has a tool they will sell you.I did mine last summer and it was a bitch pulling out.The thing not to do is bang on the prop to remove the shaft.
good luck
Mon Feb 11, 2013 1:57 pm
