It is currently Tue Apr 07, 2026 4:10 pm
[ 8 posts ] |
Cubman
Joined: Sun May 16, 2010 8:53 pm Posts: 254 Location: East TN
 LT on Gatortrax Rogue
Can you run a longtail on a Gator Trax Rogue with huntdeck? Or will the motor hit the false transom when you pick the prop up out of the water?
| Wed Jan 23, 2013 12:48 pm |
barnes_53
 Re: LT on Gatortrax Rogue
the handle on the longtail has a curve that extends upward that allows for transom clearance. Since the motor is mounted further back I would think your chances of hitting the false transom are lower than with a traditional transom.
| Wed Jan 23, 2013 12:52 pm |
Cajunwannabe
Joined: Wed Jan 28, 2009 3:40 pm Posts: 188 Location: Wishing I was in SE La.
I believe the "tail" will hit the false transom. If mounted on the false transom it will be a bear to turn.
| Thu Jan 24, 2013 9:03 pm |
irons
Joined: Sun Apr 22, 2012 4:58 pm Posts: 24 Location: Connecticut
How do the Longtails fair with a huntdeck??? dont see to many of them after looking around the site...just curious
_________________ 1652 Alumacraft Waterfowler / 35HP Backwater LT
| Mon Feb 18, 2013 4:38 pm |
Cajunwannabe
| Thu Feb 21, 2013 4:49 pm |
irons
Sweet thanks, so as in the thread above you just don't mount the motor on the huntdeck? Just the transom?
| Thu Feb 21, 2013 9:25 pm |
Cajunwannabe
If you mounted it all the way back on the rear hunt deck transom it would be impossible to turn. You would have to be outside the boat trying to steer it.
| Fri Feb 22, 2013 6:43 am |
irons
Touchè sir. Good call
| Sun Feb 24, 2013 1:40 pm |
[ 8 posts ] |
