It is currently Tue Apr 07, 2026 2:05 pm
[ 7 posts ] |
Simsknives
 16hp duromax question
where and how do yall hook up your throttle cable? post pictures if you can please.
Thanks Conley
| Fri Mar 08, 2013 12:22 am |
SwampDonkey1
Joined: Tue Mar 08, 2011 10:09 pm Posts: 923 Location: North Central KS
 Re: 16hp duromax question
loosen the throttle arm nut (might have to remove the gas tank) this should help the arm swing freely and smoothly. Might have to add a stiffer spring to act as a return, or you could do the same on the governor arm...
_________________ 1436 Lowe -Workin for the man, Huntin when I can...-
| Fri Mar 08, 2013 11:29 am |
Simsknives
but where do you mount the throttle cable to?
| Mon Apr 01, 2013 8:44 am |
SwampDonkey1
We drill a small hole to pass the cable through the arm and put a stop on the other end, then took the orginal return spring off and mounted a stiffer one in the original hole and the other end to a nearby mounting bolt for the tank I believe.
| Tue Apr 02, 2013 2:02 pm |
jsshivers
I had to deal with this the other day. Since I had a brand new motor I didnt want to bypass the governor until I had at least broken it in. I ended up running the cable up near the carb and over to the governor arm. Ran the cable through one of the holes and attached cable stop. I made sure to adjust it to where it just barely tugs on the arm when I pull the throttle lever, otherwise it overpowers governor and you would of been better off doing it a different way.
Once I brake it in and do a few mods namely valve springs, I will look at hooking it up as SwampDonkey1 does.
| Fri Apr 05, 2013 10:08 am |
JKD
| Tue Apr 09, 2013 3:32 pm |
SwampDonkey1
Still running strong after being left outside and running for 3 seasons
| Tue Apr 09, 2013 7:37 pm |
[ 7 posts ] |
