It is currently Tue Apr 07, 2026 12:58 pm
Reply to topic  [ 8 posts ]
 1448 tracker lt ?
Post 1448 tracker lt ?
Is a 25-27 hp long tail too much for this boat. Its rated for 25hp outboard
Mon Jun 24, 2013 6:49 pm
Post Re: 1448 tracker lt ?
i wouldnt do it, it mit eat up tour transom. that boat is rated for a 25 hp out board not a mud motor so u would wana go a lil smaller
Thu Jun 27, 2013 11:17 am
I have a friend with a 27 hp lt on 1448 mv alumacraft and it works just fine. It has pods on the back to help with flotation though. Without pods, it would damn heavy in the back I would think...
Mon Jul 01, 2013 8:59 pm
Id say go for it if you got a shot at it, I run a 16hp on a 1436 80's tin can and it does pretty good but i wouldn't hesitate to go for the 23hp. If you feel like you need to you can weld a couple of knee braces from the transom down to the floor to help stiffen your transom up.
1436 Lowe
Mon Jul 01, 2013 9:16 pm
best bet get you a copperhead 18hp they only weigh about 140 pounds and they are verry impressive. but ur budy is bound to loose a transom u dont wana take that risk
Tue Jul 02, 2013 7:51 am
yea them pods help but on a surface drive motor it takes away performance
Tue Jul 02, 2013 7:52 am
I have a 27hp Mud buddy on a 14' Xpress allwelded works just fine. I would definitly not put it on a rivited boat.
14' Xpress 27HP MUDBUDDY
Tue Jul 02, 2013 12:01 pm
Id put one on. We have a bunch running of those same size boats running around up here with 16, and 23s even one with a 27 kohler and they run just fine a couple had to re do the transom but the otheirs didnt.
Tue Jul 02, 2013 5:54 pm
