It is currently Tue Apr 07, 2026 4:24 pm
Reply to topic  [ 19 posts ]
 Mad Mud Motor Plans...Are they woth it???
Post Mad Mud Motor Plans...Are they woth it???
i was thinking about buying the Mad Mud Motor LT plans but wanted to hear some success stories...i mean are they worth the 30 bucks...
I already have two Kohler Command Pro 7hp motors new in the box...kinda wanted to build a mini twin long tail...thought it would be kinda fun on the back of a 12 foot jon
anyway...so if you have pics or success stories pm me, message me on here or email me
cooperwright85@hotmail.com
Sat Feb 05, 2011 8:42 pm
Post Re: Mad Mud Motor Plans...Are they woth it???
Boats aint fun on the bottom, all that weight you WILL more likley than sink a 12' boat.
Sat Feb 05, 2011 8:57 pm
it will more than likely wind up on either a 14' or 16' boat...that was ore like a matter of fact statement...
Sat Feb 05, 2011 9:02 pm
Why spend the money on two frames when you could buy a bigger block?
Sat Feb 05, 2011 9:13 pm
i mean ive already got the motors...so i figured id either make 2 7hp LT's or 1 twin
Sat Feb 05, 2011 9:19 pm
any how...the point here is if the mad mud motor plans are worth it or not...want success stories or disasters
Sat Feb 05, 2011 9:26 pm
My guess would be it varies person to person, longtails are pretty simple... If you are a compitent welder and can get the right stuff it shouldn't be bad
Sat Feb 05, 2011 9:46 pm
ya id say it just depends on if you really know what youre doing or not. tons of people have built great motors without em, and some should have had more guidance, like me....
just keep lookin at other longtails and see how confident you get, im sure you can do it wihtout the plans.
Save your confederate money, cause the south WILL rise again
homebuilt 11 HP greyhound LongTail
-1436 flatbottom
Mon Feb 07, 2011 1:04 pm
how about you run both them motors on the same shaft and let us know how it works
Mon Feb 07, 2011 5:03 pm
plans are fair, most valuable part is the parts list that comes with it that gives you what and where to buy the materials, very good starting point that you can build upon or modify based on size motor you install. if you are planning to build it yourself they are worth the 30.00
gtr35 gt 1854 / w gatorglide
12 ft 11hp longtail
14 ft 10 hp longtail
Merc 225hp TR20
Mon Feb 07, 2011 6:02 pm
What if one motor will crank and the other one won't? :lol: :lol: :lol: :lol: :lol: :lol: :lol:
1648 Tracker 50 Merc
Team Topwater-Alabama
Mon Feb 07, 2011 6:14 pm
ride in circles i reckon
Tue Feb 08, 2011 6:46 pm
ive purchased them, it gives a good starting point and a good view of how everything works ive did mods to mine tho for it to perform better than what they did, the parts list is the best part
Mon Mar 07, 2011 8:47 pm
I have the plans, built two of them now. Very happy with them, Just take your time it will work out. I run a 6.5 hp on a 12' jon boat pushes it just fine.
Fri Mar 18, 2011 7:10 am
Yea, what MudMarshall said. I bought the plans. The parts list is the best part, because it tells you what parts to use, and where to get them.
14' Dixon Warrior bateau w/ 13hp Honda Longtail
Sat Apr 02, 2011 12:10 am
So the general consensus is they are worth the $?
mudslinger - Missouri
Homemade 13' layout boat
Homemade 6.5 hp Long tail Mud Motor
The second amendment is what makes the first amendment possible...
Sun Jul 28, 2013 12:34 pm
If you need a parts list, the design portion isnt hard they just give you a cookie cutter pattern to go off of. If you print off some photos of production longtails and get an idea of some of the measurements you can look at the photos and "say that part goes from there to there and is about this far down on the frame" ect. and you will get close, or if you know someone with a longtail you can borrow and are able to look at pieces and copy the frame its shouldn't be that hard.
1436 Lowe
Sun Jul 28, 2013 5:28 pm
I have the plans and yes they do help,the parts list is a great asset and the pictures help guide you in the right direction,my suggestion would be to get the plans to help get you started . use the search function on this site and read as many post's as you can.then search the web and look at as many pictures of LT mud motors as you can find. it should start to come together for ya and if all else fails ask questions!
Tue Jul 30, 2013 9:37 pm
I bought the plans and the only info I used was the motor base plate measurements, cav plate and skag design. All the rest of the parts I upgraded and used different parts taken from other mud motor manufactures. If you do some surfing you can get some really good ideas. Dont re invent the wheel, someone has done it and posted picts somewhere. Check the different manufacturers web pages. So were they worth it....at the time when i was just starting yes.....looking back maybe not I could have figured it out myself if I was more patient.
Good luck
Tue Aug 27, 2013 12:29 am
