simopj11
Joined: Thu Oct 15, 2009 7:52 pm Posts: 11 Location: Interlochen, MI
 How hard is too hard?
Alright fella's I've got a new prop, seals, and nut set on the way for my 23Van GDLT. Figured I would start the process today by getting the old nuts and prop off. Guess what, I got the two lower nuts and washers off but the prop just will not budge. I get the part about 2x4's and fancy prop wrenches to turn the thing. My Question is how hard can i pull on that thing. I've got a big ass screwdriver in the bottom part of the U-joint and a 4' long chunck of 2x4 hogged out to slide over the shaft. I can put a ton off pressure on it, hell I'm almost lift'n the boat... It just seems that if i pull any harder i'm gonna break something. So HOW HARD IS TOO HARD TO WRENCH on this thing...
Thanks
_________________ Ice'n Up, Find the Open Water.
Alumacraft Waterfowler 16 / 23 GDLT
| Tue Oct 20, 2009 4:16 pm |
Kirby
Joined: Thu Oct 08, 2009 6:37 pm Posts: 99 Location: E. Oklahoma
 Re: How hard is too hard?
Heat it up a bit with a propane torch
_________________ Boomer Sooner!
| Tue Oct 20, 2009 4:21 pm |
shallow water master
Joined: Tue Jun 16, 2009 8:27 pm Posts: 1803 Location: Belle Chasse La.
| Tue Oct 20, 2009 5:00 pm |
Mike W.
Joined: Thu Jan 15, 2009 2:26 pm Posts: 146 Location: Vanceboro, NC
A propane torch ain't gonna get hot enough. The prop will draw off the heat too fast. Go borrow your buddy's acetylene torch and heat JUST THE PROP HUB! You can pull as hard as you want, The shaft has enough flex to keep you from breaking it, MOST OF THE TIME  ! Be aware that you can use whatever methou you want to UN-SCREW the prop, but, once you start, it is IMPOSSIBLE to screw it back on, due to the weedless shape of the blades If you DO break the shaft, a new one was under $50.00 last time I bought one. (About 4 yrs. ago). The EASY way to solve the problem is to suck it up and buy a new shaft! Good luck
_________________ "They call us civilized, cause we're easy to sneak up on!"
| Wed Oct 21, 2009 5:09 am |
Gigafowl
Pipe wrench or big crescent on the hex right behind the prop, let it stop on the cav plate and 2x4 are my weapons of choice...
Used lil liquid wrench at the threads and propane torch at prop hub after 2 or 3 heat and cool cycles they usually break free - there is a freeze spray at the auto parts house too that I have heard helps...
| Wed Oct 21, 2009 6:35 am |
simopj11
Thanks Alot Fella's
Everything showed up today. So now I have to get that damn thing off.. Got a new torch, a new 2 x4, a six pack, and all night. Wish me luck..
| Wed Oct 21, 2009 3:58 pm |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
i had the same problem but i soaked ol' gal every day for a week with penetrating oil, mapp gassed the hub, then big ass pipe wrench and 5 foot cheater bar.
| Sat Oct 31, 2009 8:10 pm |
Country
I remember lifting my boat and trailer the first time! I also remember to use antisieze every time now!
| Sun Nov 01, 2009 12:59 pm |
simopj11
Just to let you fella's know, it took pulling the shaft, a pipe vise and a acetylene torch. but i got her off.
| Mon Nov 02, 2009 10:41 pm |
