It is currently Mon Apr 06, 2026 2:17 pm
Reply to topic  [ 11 posts ]
 Water in shaft housing?
Post Water in shaft housing?
Ugh!! Have water somehow getting into my shaft housing 23 HP vanguard GD no play in the prop so I assume the bushing is good.
16' skiff 23 GDLT
Tue Nov 12, 2013 5:03 pm
Post Re: Water in shaft housing?
Lower seals ?
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Tue Nov 12, 2013 5:22 pm
Lower seals being bad is about the only way that's possible.... Unless you have somehow mounted your motor to the bottom of the boat instead of the top lol
-Custom pool noodle
-stage 4 water wings
Tue Nov 12, 2013 6:51 pm
Clean the grass from in between the nut and seal housing after every trip. That shit dries out like rope and eats seals.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Tue Nov 12, 2013 7:18 pm
Tue Nov 12, 2013 8:20 pm
Is it a grease seal or an oil seal?
16' skiff 23 GDLT
Thu Nov 14, 2013 7:22 pm
Grease seal
-Custom pool noodle
Thu Nov 14, 2013 7:30 pm
FYI, old style is two seals back to back. New style is two seals back to back and a scraper seal. Scraper seal is closest to the prop and the side with writing faces the engine.
Thu Nov 14, 2013 10:02 pm
Thank you all! I believe it is a newer style. I could more than likely get the grease seals from Napa? I would just order them from GD but I need to get this resolved this weekend.,
16' skiff 23 GDLT
Thu Nov 14, 2013 10:46 pm
You may find something that will get you by, but I believe the ones from GD are a proprietary design that's manufactured for them.
Thu Nov 14, 2013 11:08 pm
In addition to Kibb...How do you store your motor? If you store it outside and uncovered, you could have water intrusion from the top near the universal joint. Unlikely, but I would check to rule it out.
Sun Nov 17, 2013 7:14 am
