It is currently Mon Apr 06, 2026 2:17 pm
[ 3 posts ] |
T_Moore
 21 Briggs V-twin
Motor will turn 4300Rpms out of water... under hunting load in the water the max I could get was 2850. If I would close the choke a little the motor would begin to pick up then start to die..
Does that sound like a fuel issue to you guys? I was thinking maybe the jet in the carb was clogged or its just not getting enough fuel (may need to add an electric fuel pump)... it idles great and runs fine, just doesn't seem to run right under a load.
open to ideas.
| Tue Nov 12, 2013 4:35 pm |
139sst
 Re: 21 Briggs V-twin
Sounds like a high speed jet issue to me.
| Thu Nov 14, 2013 4:42 am |
dead duk
Joined: Thu Jun 25, 2009 10:45 am Posts: 147 Location: Longview,Texas
Is the motor new? Timing could off, check the carburetor, fuel line. Somehow the motor is starving when under a load. I had a buddy who added an electric fuel pump and his motor ran much better after installation.
| Sun Nov 17, 2013 7:17 am |
[ 3 posts ] |
