It is currently Sat Apr 11, 2026 7:02 pm
Reply to topic  [ 15 posts ]
 16hp long tail on 14 foot riveted boat?
Post 16hp long tail on 14 foot riveted boat?
How do you guys think a 16hp long tail go devil would do on a 14 foot riveted flat boat?
Mon Nov 18, 2013 8:50 pm
It runs good enough! Know a guy that ran one on a 1436 and it was a little heavy but got the job done.
Sent from my beeper.
Mon Nov 18, 2013 8:57 pm
Post Re: 16hp long tail on 14 foot riveted boat?
What you think the top speed would be?
Mon Nov 18, 2013 9:34 pm
17*38 Klibert 23GDLT
Mon Nov 18, 2013 10:09 pm
I run a 16hp single cylinder on a 1436 riveted and hit 16 or so empty but with a heavy hunting load itll usually hang around 10 but still pushes through the crud...
1436 Lowe
Tue Nov 19, 2013 12:42 am
fresh prop you'll run 17-19 empty 13-15 with 2 ppl and light load.. 12 with 2 ppl/dog hunt load.. 3 ppl there is no stepping it
Tue Nov 19, 2013 2:11 am
fresh prop you'll run 17-19 empty 13-15 with 2 ppl and light load.. 12 with 2 ppl/dog/ hunt load.. 3 ppl/ hunt load there is no stepping it
Tue Nov 19, 2013 2:12 am
I would think you'd be fine. How wide is the boat? I have a 23hp backh20 SWOMP (175 lbs) on a 14 ft. Mod-v Jon. It's 48 inches wide at the bottom.
Backwater Swomp 23 / Lowe L1448M
Fri Nov 22, 2013 8:17 pm
I ran a. 16 lt for years , 15'x36 skiff. , pushed that thing fine . Coupe 75 has that motor now on a 14' crawfish hull and it runs fine , call me crazy but I put a 25 GD lt on my 15x36 skiff , not much noticeable speed difference. , but it pushes a heavier load easier. .
H Finn
GATOR GLIDE PROSTAFF
BACKWATER PROSTAFF
http://www.gatorglide.com
Coupe rest in peace brother
Fri Nov 22, 2013 8:32 pm
i got a 6.5 predator on a 1436 runs 13-14 with just me and 10 with 2 people and normal hunt load
Fri Nov 29, 2013 6:54 pm
I run a 20 hp longtail on an ol riveted 1436. No problems with it as far as water coming over that back or in on turns. Just don't go crossin any oceans with it.
Sat Nov 30, 2013 7:20 am
I had a 16LT on a Tracker 15. It ran about 15mph loaded with two guys. I considered replacing it with some of the smaller surface drives on the market, but ended up with a whole new rig. If you're that worried about speeds, looks at some of them. I got a little nervous after researching them though. I found alot of reviews that kind of pushed me away from getting one.
Tue Dec 03, 2013 7:23 am
I run a 20hp beavertail on a riveted 1436... I'm never going to set a land speed record but there's very few places I can't get.
1844 GD with 35HP GDSD
Mon Dec 09, 2013 9:49 pm
Got a 16hp longtail godevil on a 14x36 crawdad and it floats and handles it fine. I am not setting a speed record with it but it runs 16 unloaded 15 loaded. Goes anywhere I dare to take it. A longer boat would improve speed due to more planing surface. 14x36 will take the 16 with no problem.
Tue Dec 10, 2013 8:08 am
Tue Dec 10, 2013 9:15 am
cron
