It is currently Mon Mar 23, 2026 8:56 am
Reply to topic  [ 2 posts ]
 23 hp godevil Changing go-devil seals
Post 23 hp godevil Changing go-devil seals
went run my go-devil today and while i was running the seal on the upper end of the shaft (near the motor) caught on fire. I removed the the shaft. Now how do i replace lower and upper seals? Is there anything i need to know on replacing these? The shaft had no scarring on it. any info would help thanks
Thu Dec 17, 2009 9:50 pm
Post Re: 23 hp godevil Changing go-devil seals
Go to the Godevil site and download their owners manual it will step you through changing the seals which is really not that hard. If you have any play in shaft at the prop end you will need to change the bushing also which is not hard either.
Tue Dec 22, 2009 9:15 pm
