It is currently Fri Apr 10, 2026 2:34 am
Reply to topic  [ 13 posts ]
 23 hp Go Devil question
Post 23 hp Go Devil question
My longtail is having problems staying underwater when on plane. It wants to pull up out of the water. Is there anything that can be done to help keep it down. It is really wearing me out.
Fri Jun 13, 2014 10:38 pm
Post Re: 23 hp Go Devil question
Bend your cavitation plate up or cut you transom
18x40 skiff/35 hp GTR
Fri Jun 13, 2014 10:45 pm
X2 on Cavitation plate
17*38 Klibert 23GDLT
Fri Jun 13, 2014 10:57 pm
How much do I bend it up? Anyone got a pic to show me how?
Fri Jun 13, 2014 11:01 pm
Yep, take a crescent wrench with you on the water. A little goes a long way when adjusting the cav plate.
Ok so i got my crescent wrench out and bent the back of the plate up. I will take it out and test it later. Is this what everyone is talking about?
Sat Jun 14, 2014 12:15 pm
Like this
Sat Jun 14, 2014 12:23 pm
That's it. You may want to notch that plate where it bends down to the sides. My MBLT has about an inch of the top plate that extends out past the angled portion, that's where mine adjusts. It would make it a lot easier if you took a metabo or even a havksaw if that's all you have and just cut straight back toward the front of the plate parallel with the bend so it creates a bit of a 'tab' to bend. It will adjust easier and you won't pull the angled portion out of whack.
-Custom pool noodle
-stage 4 water wings
Sat Jun 14, 2014 12:54 pm
How far should I cut back? 1" or so?
Sat Jun 14, 2014 1:25 pm
1/2" to 1" would do it. Take a grinder and clean everything up so it doesn't snag everything.
You could do it this way or even just bolt a tab to the cav plate and bend that. Most will probably prefer the bolted on tab, but either way will get the job done.
-Custom pool noodle
Sat Jun 14, 2014 1:44 pm
I would cut it back about 3/4''
Uncle J Custom 1848 / 37efi GTR
Tue Jun 17, 2014 7:20 am
How tall is your transom ???
You may have a short transom LT design on a tall transom hull....
The entire cavitation plate sits at a different angle for tall transom hulls - the easy
way to tell is on the trailer when you lower the tail - the cavitation plate needs to
be exactly parallel with your hull bottom......
Go Devil can actually remove and reweld the entire plate to properly align it if you
have a mis-match setup and get it working right.....
Eat - Sleep - Hunt ! ! !
Tue Jun 17, 2014 7:28 am
I'm running a gdlt with a honda gx630 on a tall transom 1848. I have the cav plate bent up at a pretty good angle. With all my bowfishing gear and one guy it runs great, with just me it wants to come out of the water at WOT. I'm not making runs farther than a mile or two so it's not really a big deal. I might weld a 1" extention on the cav plate. I would cut the cav plate off and re-angle it but I also use this motor on my short transom 1448 for duck season. Keep playing with the angle and it should eventually work for you.
Tue Jun 17, 2014 5:58 pm
