It is currently Fri Mar 20, 2026 4:08 am
Reply to topic  [ 3 posts ]
 Grease leaking around pressure lubricator threads
Post Grease leaking around pressure lubricator threads
Ok so here is my problem, I have some grease leaking around the threads where the pressure lubricator screws into the LT shaft, on a GDLT. I cleaned up the grease run it for a lil while and the grease starts to leak out of around the threads. I unscrewed the lubricator from the shaft and pulled the old teflon tape off and put somemore on and screwed it back in and snugged it up a lil and it's still leaking some grease. Anyone got any ideas on how to stop it? Thanks.
23hp GDLT on 16x38 GD boat
When up to your nose in shit, don't open your mouth.
Mon Jun 08, 2015 5:22 pm
Post Re: Grease leaking around pressure lubricator threads
Tighten it more
Mon Jun 08, 2015 5:56 pm
Check is there is a crack in the plastic housing.
the leak may be there an not in the thread.
Mon Jun 08, 2015 6:45 pm
