It is currently Mon Mar 23, 2026 11:50 am
[ 4 posts ] |
High transom or low transom model how do you tell the diff
colnz
Can someone explain how do you tell whether your longtail is a high transom model or a low transom model? What is the key to this, I am thinking it is something in the motor bracket but I could be way off. thanks.
| Fri Jan 15, 2016 10:51 am |
jakehawk9
Joined: Wed Jul 01, 2015 6:06 pm Posts: 1447 Location: South central, ks
 Re: High transom or low transom model how do you tell the d
Measure from the bottom of the u joint to the end of the shaft. Most short transom longtails are less than 72"... using that method, if it's a little less than 72" that's because there's about 1 or 2 inches of shaft in the u joint. If it's considerably less like in the neighborhood of 60" it's a short transom.
| Fri Jan 15, 2016 12:40 pm |
brycecheramie
I thought most longtails were made for short transom?
| Fri Jan 15, 2016 8:03 pm |
jakehawk9
Not entirely true. alot of places have an option on shaft length if you are ordering directly from them. For example backwater has a 59" and a 71". You need a longer one for a tall transom due to shaft and prop angle relative to the water line. I'm pretty sure backwater had the different shaft lengths listed as tall and short transom
| Fri Jan 15, 2016 8:57 pm |
[ 4 posts ] |
