It is currently Mon Jun 17, 2024 3:20 am
[ 8 posts ] |
spooky
![Post Post](./styles/acidtech_tiger/imageset/icon_topic_latest.gif) throttle cable question
how are yall hooking up the cable to the linkage? I got a bicycle brake lever for the throttle, but not sure how to hook the cable on the engine side. thanks
Tue Aug 08, 2017 11:43 am |
![](./styles/acidtech_tiger/theme/images/spacer.gif) |
Will C
![Post Post](./styles/acidtech_tiger/imageset/icon_topic_latest.gif) Re: throttle cable question
What kind of engine are we talkin about
Tue Aug 08, 2017 3:37 pm |
spooky
not sure. what I can say is it was blue (before I camo'd it) and it is a 13hp. got it on a trade. here is a thread I made that might help.. I think its a duromax??? viewtopic.php?f=6&t=70894
Tue Aug 08, 2017 4:06 pm |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
Hook one end to the inside slot on the lever, run the other end to the stock carb linkage . Get all your slack out so lever is idle at natural place. Make sure you add a spring to back of linkage, enough to snap your lever back to nuteral as you let off.
H Finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
Tue Aug 08, 2017 5:28 pm |
spooky
Tue Aug 08, 2017 5:39 pm |
huck Finn
Gotcha, well hmmm I've seen the lead cylinder types at tractor supply. They have a pre drilled hole with a set screw on the bottom. You have to feed it thru then screw it down to hold cable secure. Probably work for you .
H Finn
Wed Aug 09, 2017 7:16 am |
Russ
Either get the cable end like huck spoke of, or get out your soldering gun and make it. Bend the cable with pliers to fit the carb linkage, then use solder to stiffen the bends and end and thicken it just a bit.
Wed Aug 09, 2017 8:53 am |
spooky
alright,, thanks yall. Ill look for those things with the set screw AND solder it in. I tend to go overboard.
Wed Aug 09, 2017 6:30 pm |
[ 8 posts ] |
Users browsing this forum: No registered users and 120 guests |
