It is currently Thu Mar 19, 2026 12:58 pm
[ 5 posts ] |
phoneman7
Joined: Tue Jan 13, 2009 7:16 pm Posts: 250 Location: Sumter, SC
 RPM question
My 23 is running 3310ish with just me on my 1638 gd boat. It has 11 hours on it. Ive read I should be in the 3600 range empty. Do I need to adjust governor some. Out of water is 39and some change
_________________ 1638GD with 23GDLT 542 war eagle with 25 yamaha A few pirogues
| Wed Sep 20, 2017 1:20 pm |
phoneman7
 Re: RPM question
btw all floatation has been cut out so boat isn't waterlogged and no hooks in the bottom
| Wed Sep 20, 2017 1:21 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
 Re: RPM question
I'd want to be in the 3800 range with a load, you can run it up around 4K light and 42-4300ish on the governor. You probably need tuning and maybe a prop change to get you there.
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
| Thu Sep 21, 2017 9:48 pm |
50fps
 Re: RPM question
I put one of PVT rev kits in my 23 gdlt and set oow rpms at 44-4500, I also ran a BBlades 9x7 prop with decent results.
| Mon Sep 25, 2017 6:19 am |
rbs
Joined: Thu Sep 03, 2015 6:02 am Posts: 6 Location: Decatur, IL
 Re: RPM question
I need to call B&S with my engine info, 18hp Vanguard, and find out what RPM's the motor is supposed to turn. Installed new shaft , seals, prop last year but haven't had the opportunity to run it on a boat, but that is going to happen shortly. Tach shows 3700 Rpm's with no load, and reading here that looks like it might need to be tweaked a little. Looking for opinions from folks, thanks. FYI, I installed the GoDevil factory prop, I believe 9x4.
| Thu Sep 28, 2017 6:23 am |
[ 5 posts ] |
