It is currently Tue Dec 09, 2025 12:08 pm
[ 5 posts ] |
Backwater hex prop coming loose
hawilson
Got a 26.5 full frame Backwater. I have a hex shaft and prop. The problem I am having is after 1-2 trips (average 2 hours a trip) the prop is loose. From the prop out I have a SS washer, SS nut, and nylock jam nut. They are all pretty well tightened. I have even used an impact driver to tighten. It's not rocket science but I am clueless as to how to prevent it. Anyone else experience this? Any suggestions? A loose prop makes a hell of a racket when spinning.
| Mon Mar 25, 2019 9:12 am |
FRANKtheTAU
Joined: Thu Dec 29, 2011 10:30 pm Posts: 1386 Location: West TN
 Re: Backwater hex prop coming loose
I'd replace the nylock nut.
_________________ 40 Backwater SWOMP Lite / 1752 Alweld Mud
| Mon Mar 25, 2019 1:29 pm |
SETx Longtail
Joined: Sun Sep 01, 2013 2:53 pm Posts: 3480 Location: Hardin County, Tx
A drop of locktite does wonders
_________________ #CFFITR
-Custom pool noodle -stage 4 water wings
| Mon Mar 25, 2019 2:15 pm |
hawilson
A little more info. The play or slop that develops is the same side to side play that the hex prop has on the hex shaft before it is tightened down. Guess the shaft has rounded some causing the play. I have a spare shaft and the prop fits pretty snuggly on it so I assume the it is the shaft that is rounded out some and not the prop that is wallowed out. Talked to Jake at Backwater about it, He offered 2 solutions. 1) He said the play should not cause any issues and I could just tighten it down when it develops. 2) Go back to a threaded prop and shaft. I went with the hex shaft so I could easily remove the prop if needed. Always heard about issues with removing frozen props and nuts from a threaded shaft. I was removing the prop quite a bit while I was experimenting with the prop size and shims for the tracer plate. I have all that worked out now so removing it should be only for replacement and maybe occassional maintenance.
| Mon Mar 25, 2019 5:27 pm |
mnugent
Using an impact can cause the nylon to strip out
| Tue Mar 26, 2019 4:59 am |
[ 5 posts ] |
