It is currently Tue Dec 09, 2025 12:41 pm
[ 4 posts ] |
tractor battery or group 24?
Glades Ranger
Backwater recommends a tractor type battery, like the Interstate SP-40, 350 CCA, weight 18.4 lbs. I am trying to shave some weight and space under the bow. I've been using a group 24 type Marine starting battery 650 CCA, weight 43 lbs. I only use the battery for starting my BW 26.5 EFI swomp longtail, running lights (LED) before daylight, and occasional bilge use. I use a handheld rechargeable spotlight so no further drain. Two SP-40's would still weigh 6 lbs. less than one 24. Anybody successfully using a tractor type battery? Any thoughts, suggestions are welcome!
| Wed Apr 24, 2019 7:54 am |
huck Finn
Joined: Thu Jan 31, 2013 5:42 pm Posts: 1913 Location: Conroe tx
 Re: tractor battery or group 24?
It is a lawn mower engine.. most deck type mowers have that small battery you are describing. It will work, however, I run a small 12 volt cca battery for starting and the accessories you have.
H Finn
_________________ Ole black water keep on rolling
18x54 Uncle J -GTR - with the koolaid Back H2o SWOMP 23 SS stage 2 15x36 GD Duck Skiff GATOR GATOR GLIDE PROSTAFF BACKWATER PROSTAFF http://www.gatorglide.com
Coupe rest in peace brother
| Wed Apr 24, 2019 8:59 am |
Will
Yep. No need for a big battery if you're only cranking and a couple of lights.
_________________ Before the internet, the majority of the village idiots stayed in their villages.
| Wed Apr 24, 2019 9:25 am |
longboman
23hp backwater on my 15ft boat. I run the small battery also. Running lights, 2 interior led lights, bilge and 11 inch spot up on the bow. 2 years never a problem. Remember even if you loose juice to start...just hand crank the motor to get going.
| Wed Apr 24, 2019 9:22 pm |
[ 4 posts ] |
