It is currently Mon Mar 23, 2026 3:14 am
Reply to topic  [ 5 posts ]
 Mud buddy lower seal housing
Post Mud buddy lower seal housing
Hello, does anyone know how the lower seal housing is held onto drive shaft tube? The model is a year 2000. Thanks
Thu Aug 13, 2020 9:14 pm
Post Re: Mud buddy lower seal housing
The housing is part of the tube. Should just be a cap on the end with 2 flat sides that's reverse threaded (righty loosey lefty tighty) to put a big crescent wrench on and unscrew it. The seals are in the cap.
#mudmotor>physics
Fri Aug 14, 2020 6:06 am
The bearing housing is pressed onto the drive tube. The seal cap is reverse threaded into the bearing housing.
Fri Aug 14, 2020 11:31 am
I appreciate the info. Do you know how much clearance there should be between the housing cap and the nut that is closest to it?
Fri Aug 14, 2020 8:13 pm
1/8 to 1/4inch.
MB 35hp LT/1754 Grizzly
Sun Oct 18, 2020 5:40 pm
