It is currently Thu Mar 19, 2026 1:22 am
Reply to topic  [ 2 posts ]
 Go devil prop installation
Post Go devil prop installation
I am confused by the instructions for installing prop on go devil. It says it should be able to rotate 12 to 2? Is this on the threads? Like you dont tighten the nut and jam nut all the against the prop? What is the point of this? It seems like eventually it will just lock down tight against the jam nut and not be able to move freely anyways.
Sat Mar 27, 2021 6:19 am
Post Re: Go devil prop installation
The "theory" is that you leave it a bit loose in the hopes that later
it won't be a nightmare to get it back off....
Buy or borrow the GD prop removal tool when it is time to change props
and put a good marine grease - like the GD shaft grease - on the threads
and spin the prop on and off a few times before final greasing and locking
the retaining nut down... Also make damn sure you use the soft brass
washer between the prop and final stop...
Without the proper tool - it is a nightmare to get the prop off two or three
seasons later after salt water marsh use - no matter what you do....
Eat - Sleep - Hunt ! ! !
Sat Mar 27, 2021 7:08 am
