It is currently Sun Mar 29, 2026 11:06 am
Reply to topic  [ 21 posts ]
 did godevil ever use a motor with gas tank on top
Post did godevil ever use a motor with gas tank on top
Does anyone know if godevil ever used the 16hp vangaurd with the motor mounted on top. buying one and guy said that it is godevil but i never saw that type used. he said it is an 2002 model.
Sun Aug 29, 2010 11:11 am
Post Re: did godevil ever use a motor with gas tank on top
i dont think so. my buddy has a model around there and it aint got one.
Sun Aug 29, 2010 12:29 pm
I used to have a 13 mb with the tank mounted on the motor...Don't know if godevil made on for sure, but its certainly possible.
Sun Aug 29, 2010 2:55 pm
Cb was your motor a v twin? i dont think they put built on tanks on v twins.
Sun Aug 29, 2010 2:56 pm
Good question. I don't remember. I destroyed the boat it was on before I had to change the oil or plugs in it, and never really paid attention to motor stuff back then. It very well may have been a single cylinder. My brother and one of my buddies both have 16 briggs motors, and both have external tanks...
The 13 was a honda. Only other I ever remember seeing with the tank on top was an 11hp briggs...I dunno, call go devil and ask.
Sun Aug 29, 2010 3:13 pm
maybe his motor isnt a 16, i dont see where there is enough room on a v-twin for a tank unless its directly above the governer and throttle stuff. then the wieght would be an issue though.
Sun Aug 29, 2010 3:18 pm
Good point woodie. If it is a godevil, or any major brand for that matter, it will have a serial number on it. Wherever the serial plate is should be marked with who built it. Call them and ask what the motor is. If its a single cylinder, its not a 16 though.
Sun Aug 29, 2010 3:23 pm
well i did a search, there were some extremely old 16 hp briggs with built on gas tanks (like mid 70's) but i saw nothin new with it.
and cb, your 13 was a single cylinder.
Sun Aug 29, 2010 3:33 pm
thanks guys, im headed down there to look at the motor tommarrow. i dont believe it is gd just because there is no gd plate on the upper left hand corner of the motor. but here is the pic he sent me.
Sun Aug 29, 2010 4:19 pm
I think thats a gd bro. The shaft and the handle have gd all over them...
http://godevil.com/Images/23Vanguardenginelarge.jpg
The tank may be some goofy aftermarket thing. I'm sure you could remove it, and use a tank in the boat like the rest of us.
Sun Aug 29, 2010 4:34 pm
thats 100% go devil. im sorry i mislead you about the gas tank :oops: :oops: but ive been wrong before. i would take it off and have a regular tank personally.
Sun Aug 29, 2010 4:37 pm
Thats a odd lookin motor. never seen one with a muffler on the bottom!
Sun Aug 29, 2010 8:42 pm
he sold the motor yesterday
Mon Aug 30, 2010 7:22 am
Yep that might be a GD frame but that engine didnt come on it. I bought the same set up and it was a lot of extra work. i asked warren coco and he said they never would use that set up, way to much weight on transom. you would have to buy a air breather, different carb "that one is a gravity fed",different muffler, and throttle cable.
Mon Aug 30, 2010 5:46 pm
Btw that is a briggs set up used on golf carts, skid steers,pressure washers ect.
Mon Aug 30, 2010 5:55 pm
Carb would be the same just needs a fuel pump. muffler would still work but has more back pressure
Mon Aug 30, 2010 7:23 pm
nope ,different carb,the gravity fed needle and seat are different. rated at .5 psi pulse pump would flood the bowl. i learned that the hard way. plus to rig you would need to buy a valve cover for your pump a mount bracket and the crank breather tube will need to be restricted to get proper pulse. btw that muffler rig blows hot air right on your oil filter over heating yer motor.
Mon Aug 30, 2010 7:38 pm
If you say so.
Mon Aug 30, 2010 7:45 pm
1648 old style bass tracker with a...........................
50 Nissian on a 17' Lakesport.
Wed Sep 01, 2010 2:58 pm
i'm not speaking for every motor out there, a briggs and a Techumsche are not the same motors. i bought the same rig just like this one and on a "briggs" 303400 series motor the gravity fed carb would load up and flood at 2 psi which is about what a pulse pump pushes. if you look at the briggs parts manual it lists carbs for gravity fed and pump fed. they even take different rebuild kits. I got a pump fed carb and it fixed my problem. btw it ran fine before the convertion.
Wed Sep 01, 2010 3:35 pm
Also stock Nikki carbs are non adjustable and the jets arent changable. This is a dead horse anyways cuz didnt get it anyways.
Wed Sep 01, 2010 4:02 pm
