It is currently Thu Apr 02, 2026 9:31 am
Reply to topic  [ 7 posts ]
 not getting gas
Post not getting gas
my 16hp briggs longtail will turnover but nitgetting gas....i took the carb off to clean all i did was take the top cover off and 2 shots of carb cleaner and put it back together and on the motor
Fri Oct 08, 2010 6:15 pm
Post Re: not getting gas
Tear the carb all the way down cleaning all jets and openings with a tip cleaner. Make sure the float doesn't leak and valve is okay.
1644 WeldCraft / 27 GDLT
Ranger R71 / 125 Merc
Fri Oct 08, 2010 6:26 pm
imma do it tomorrow i have a lil buddy that nows a good bit about godevil motors imma have him come cheack it out i juss wanted to get some opinions on it
Fri Oct 08, 2010 6:29 pm
Make sure delivery to the motor is good, quick connects can leak air, and you may need an electric fuel pump if your tank is too far away.
Put yer face in the myrtles.
Fri Oct 08, 2010 8:00 pm
Make sure you got gas in the tank. :shock:
Fri Oct 08, 2010 8:04 pm
the gas is geeting to the filter on the motor fine it stays fukk juss no fire
Fri Oct 08, 2010 8:40 pm
Have you cleaned the fuel shutoff solenoid on the bottom of the carb??
Mon Oct 11, 2010 8:55 am
