not getting gas
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=12937
Author:  godevil16 [ Fri Oct 08, 2010 6:15 pm ]
Post subject:  not getting gas
my 16hp briggs longtail will turnover but nitgetting gas....i took the carb off to clean all i did was take the top cover off and 2 shots of carb cleaner and put it back together and on the motor
Author:  kibb [ Fri Oct 08, 2010 6:26 pm ]
Post subject:  Re: not getting gas
Tear the carb all the way down cleaning all jets and openings with a tip cleaner. Make sure the float doesn't leak and valve is okay.
Author:  godevil16 [ Fri Oct 08, 2010 6:29 pm ]
imma do it tomorrow i have a lil buddy that nows a good bit about godevil motors imma have him come cheack it out i juss wanted to get some opinions on it
Author:  DeathMetalDukk [ Fri Oct 08, 2010 8:00 pm ]
Make sure delivery to the motor is good, quick connects can leak air, and you may need an electric fuel pump if your tank is too far away.
Author:  Tenpoint [ Fri Oct 08, 2010 8:04 pm ]
Make sure you got gas in the tank. :shock:
Author:  godevil16 [ Fri Oct 08, 2010 8:40 pm ]
the gas is geeting to the filter on the motor fine it stays fukk juss no fire
Author:  postalpaul [ Mon Oct 11, 2010 8:55 am ]
Have you cleaned the fuel shutoff solenoid on the bottom of the carb??
