It is currently Sun Mar 29, 2026 7:18 am
[ 3 posts ] |
can i put a 11hp on a 6.5hp gdlt frame
d2nx80
i have a 11hp honda with a 1 " crank i would like to put on my go devil which has a intek 6.5hp crank is 3/4, shaft is 58", prop is a 7x5 i think. i know i would at least have to get a new yoke for the 1" side of the engine for it to even get going. my frame has no bearings in it just alot of grease and a seal. i know most long tails bigger than 6.5hp go to an 72" shaft. any info would be great ?
| Sun Nov 14, 2010 10:36 pm |
go-devil15
Joined: Thu Oct 28, 2010 7:30 pm Posts: 115 Location: Abbeville,LA
 Re: can i put a 11hp on a 6.5hp gdlt frame
you will need a bigger prop for sure, i dont think the shaft lenght will be a problem....
_________________ Running a homemade 14x38 skiff with the good ole' 13 h.p Go-Devil longtail
| Mon Nov 15, 2010 4:29 pm |
garjacker
Joined: Sat Oct 17, 2009 3:39 pm Posts: 321 Location: greensboro n.c.
i dont think your motor will line up. 9hp and up have a Shaft centerline: 5-1/2" (from center of shaft to bottom of base) 8 hp and below have a 4-3/16". plus motor will be heavier, making it unbalanced. best bet for more hp might be go- cart mods. websites.
| Mon Nov 15, 2010 7:18 pm |
[ 3 posts ] |
