It is currently Tue Apr 07, 2026 4:15 pm
Reply to topic  [ 9 posts ]
 What size LT for 1448 Polar Kraft?
Post What size LT for 1448 Polar Kraft?
Just picked one up cheap with a 25hp tiller and want to get a LT for it. It is rated 40hp but I think no way. I am leaning around a 25ish... Are these good boats for Lts?
Sat Jan 08, 2011 8:40 pm
Post Re: What size LT for 1448 Polar Kraft?
I ran a 24 on my 1650, the same hull I run a 35 GTR on now, it did fine. Got on top relatively quick, and ran around 18mph empty. I would think somewhere in that size range should suit you well. Move your fuel up front, battery too if you can because that short boat will squat a little bit.
Put yer face in the myrtles.
Sat Jan 08, 2011 8:47 pm
Sat Jan 08, 2011 9:41 pm
2000 model 25 Johnson with electric start
Sun Jan 09, 2011 6:15 am
I run a 23 on mine it works just fine
23 hp gdlt pushin the 14ft NoWeld "aka" the black pearl
35 hp gdsd pushin a 16/60 go devil boat
Sun Jan 09, 2011 9:57 am
I ran a 23 on a 1448 grizzly last year. At times Im not sure we could have put another lb of weight in it without going under but it got us to our hunting spot. We didnt have a fear of breaking any water speed records but it did get us to the ducks.... With a 2 man fishing load it would run fine, but again your not going to do any speed record breaking.
If the Steel aint Flying the Birds aint Dying....
Uncle J 1948 holding a LT
Uncle J 1848 w/?
Sun Jan 09, 2011 10:42 am
A buddy of mine has a 25 Go-Devil LT with 26 hours on it is grage kept and in really good condition let me know if your intrested and i will get you his number.
35 GTR on Uncle J 18/54
Tue Jan 11, 2011 6:49 am
25 gd kohler on a 14x48 lowe. Its goes good, but I wouldnt want anything smaller.
Tue Jan 11, 2011 8:17 am
i have same boat but with a 18 hp GD . when loaded up with gear, 2 people and dog, i gotta put weight in rear, bow plows down pretty bad. im looking to upgrade motor also, i think a 27hp would work good. only about 175 lbs. remember, i think you might have a 20" transom also, so make sure the LT will work or u might have to get a bracket or something.. good luck
Thu Jan 27, 2011 8:38 pm
