It is currently Tue Apr 07, 2026 11:48 pm
[ 7 posts ] |
mbeyer6762
 transom problem
i have a bass tracker hull with a 16 hp gdlt on it and the transom is at 21" would it be a good idea to cut it down to 16" or would that be 2 low?
| Sun Jan 30, 2011 5:13 pm |
go-devil15
Joined: Thu Oct 28, 2010 7:30 pm Posts: 115 Location: Abbeville,LA
 Re: transom problem
that is what go-devil reconmends the transom height to be
_________________ Running a homemade 14x38 skiff with the good ole' 13 h.p Go-Devil longtail
| Sun Jan 30, 2011 5:29 pm |
mbeyer6762
 Re: transom problem
would it be to low for that style hull with no flotation in the back? if so could i put pods comin off the back
| Sun Jan 30, 2011 5:48 pm |
go-devil15
 Re: transom problem
how big is the boat?
| Sun Jan 30, 2011 6:10 pm |
mbeyer6762
 Re: transom problem
1634
| Sun Jan 30, 2011 6:13 pm |
go-devil15
 Re: transom problem
first off im pretty sure if you have a boat that skinny, it will get a little hairy at times......i know for sure your boat is long enough, as for width im not to sure...i would want to run a 16 on a boat that skinny, id go with atleast a 38 inch bottom....
| Sun Jan 30, 2011 6:17 pm |
harbday
Joined: Wed Jan 14, 2009 8:52 pm Posts: 37 Location: Tallahassee, FL
 Re: transom problem
i have a 1648 and cut the transom down to 16 with a 27 hp mblt. it sat low but i never had problems with back splash. you should be fine.
_________________ 1648 w/ 27LT Go Gators
| Mon Jan 31, 2011 11:38 am |
[ 7 posts ] |
Users browsing this forum: Google Adsense [Bot] and 1 guest |
