| GDLT handle http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=17030 |
| Author: | atlong [ Fri Mar 18, 2011 6:22 pm ] |
| Post subject: | GDLT handle |
hey guys just got me a used 16hp GDLT and got her all mounted up on the transom today and took her out for a float test (no gas tank yet) and ran into a little problem. when im standing up in the boat and have the motor with the cav plate about an inch under water, i have to bend at the knees to hold onto the handle. anyone else have this problem and bent their handle up a little bit? thanks yall |
| Author: | postalpaul [ Fri Mar 18, 2011 7:25 pm ] |
| Post subject: | Re: GDLT handle |
Holler at Go-Devil they have a "duck boat" handle I think they call it |
| Author: | atlong [ Fri Mar 18, 2011 8:37 pm ] |
| Author: | Woodiebuster [ Sat Mar 19, 2011 7:52 am ] |
How tall are ya? Do you have a 16" transom? |
| Author: | trev93 [ Sat Mar 19, 2011 10:13 am ] |
the handle will go up when you are running. whenever im at idle i just let the prop sit all the way down |
| Author: | DuckHunterF250 [ Sat Mar 19, 2011 10:27 am ] |
| Author: | atlong [ Sat Mar 19, 2011 5:31 pm ] |
| Author: | atlong [ Sat Mar 19, 2011 5:32 pm ] |
| Author: | atlong [ Mon Mar 21, 2011 11:41 pm ] |
anyone else have a idea of what to do |
| Author: | atlong [ Wed Mar 23, 2011 6:18 pm ] |
ttt...... just wanting to get some more input on this thanks guys |
| Author: | southarkhunter [ Thu Mar 24, 2011 7:38 am ] |
take it out and run it and then post back |
| Author: | Woodiebuster [ Thu Mar 24, 2011 4:57 pm ] |
Hire a midget to drive you around. |
| Author: | atlong [ Fri Mar 25, 2011 5:53 pm ] |
| Author: | jp0242 [ Sun Mar 27, 2011 3:28 pm ] |
I had the same problem on mine i took the old handle off and made a new one out of 3/4 iron gas pipe i used a pipe bender to shape it the way i wanted and put some support brackets on it i will take a pic and post it when i get a chance btw it came out looking like a z it works 1000 times better then the old one though |
| Author: | jp0242 [ Sun Mar 27, 2011 3:36 pm ] |
here is a pic before i put the braces on it i ran a piece of flat bar about 3/4 wide from the throttle down to the bottom bend and two more from there to the mount plate but i hope this just gives you an idea i will try to get a better pic of the finished product for ya |
