Swivel bracket good or bad
http://mudmotortalk.com/mmt_v2/viewtopic.php?f=6&t=17180
Author:  mudbuddy 23 [ Thu Mar 24, 2011 3:58 pm ]
Post subject:  Swivel bracket good or bad
I just got a 23lt with swivel bracket and the person told me dont trailer with
the motor swiveled in the boat good or bad.
Author:  cb5331 [ Thu Mar 24, 2011 4:11 pm ]
Post subject:  Re: Swivel bracket good or bad
That's what it's for. :? You need to put something in between the skeg and bottom of the boat to keep from tearing a hole, but that is the whole reason for the swivel bracket
Author:  Woodiebuster [ Thu Mar 24, 2011 4:13 pm ]
I have the swivel bracket, but i haul it hangin out the back for more storage in the boat.
You may want to build some type of transom saver to reduce the shaft bouncin.
Author:  Woodiebuster [ Thu Mar 24, 2011 4:53 pm ]
Here is the one I built, i took a peice of 1 1/2" 1/4" wall pipe.
I drilled holes in each end and ground a "channel" for the skeg in one end.
Pin one end into a short peice of channel iron bolted to the trailer and the other to the skeg.
bungee down the tiller and it ties all together really strong.
One mo
Author:  AJB [ Fri Mar 25, 2011 9:03 am ]
I swing mine into the boat during travel down the road. I made a bracket out of two 1x4's and a couple pieces of 1/4 inch plywood. This way the it fits down inbetween the 1x4s and doesn't sit on the floor of the boat.
Author:  take'emgator [ Fri Mar 25, 2011 10:37 am ]
The whole point in the swivel bracket is to put the motor in the boat or the shaft part anyways. Cut you out a little square out of 3/4 plywood and put it under the skeg and you'll be absolutely fine!
Author:  earl33 [ Fri Mar 25, 2011 11:46 am ]
Author:  da go get'er [ Fri Mar 25, 2011 2:52 pm ]
I personally never saw the point of one of those swivel brackets. The handle is just about as long as the shaft. I think the handle is less than a foot shorter than the shaft thus making very little difference. Maybe if you had to make it fit into a garage but thats about it. Plus it picks the engine up higher on the transome and therefore loosing performance. If you have a short shaft motor it looses even more performance due to the angle at which the prop is in the water. I find just using a ratchet strap and looping it aroud the handle works fine.
Author:  mudbuddy 23 [ Sat Mar 26, 2011 8:37 pm ]
The guy told me that the welds would brake so have you ever herd of that or is that just to scare me.
