It is currently Mon Mar 23, 2026 1:49 pm
Reply to topic  [ 13 posts ]
 Harley Longtail
Post Harley Longtail
I was on youtube looking at longtail motors. This video came up so i had to see it.... the owner of the company i work for has a motorcyle shop and plenty of old bikes layin around. if i was to talk him out of a motor for a few hundred bucks do you think its possible to put it on a 29hp mudbuddy frame? my brother is a machinest and can cut brackets to mount it with a water jet or whatever metal work is needed. What do yal think?
here is the url
http://youtu.be/4rd2d3PQSiA
WC CUSTOMS 18x48 PUSHED BY A 35GTA
Thu Apr 21, 2011 11:45 am
Post Re: Harley Longtail
its not hard to do, the tricky part is mounting the starter.
Thu Apr 21, 2011 11:46 am
Yeah that was one of the things i thought, that and the fuel situation. You were out at wallisville this weekend right?
Thu Apr 21, 2011 12:03 pm
yep! the fue situation is no prob, an e pump could supply enough. i would put electric fans on both cylinders too.
Thu Apr 21, 2011 12:24 pm
It would definatly be a different addition to all the other motors lol. Pretty cool
SENT VIA HOOT OWL!
I drive a Godevil and don't give a shit about your message!!!
MeatWagon
GoDevil 35 Surface Drive on a 13x60 MaxCraft AIRBOAT HULL!
Thu Apr 21, 2011 12:33 pm
From the smooth way that baby went through everything, I say "go for it", especially if you have access to the parts and skill to make it work. Just please have more sense than the guy that drove that thing without a grab bar. It's hard to enjoy something that cool when you're in the hospital or dead!
Thu Apr 21, 2011 1:39 pm
Thanks for posting. I've heard of Harley powered mudmotors, and I've been wanting to see one. The youtube video sure weren't very generous with any closeups of the build though. I'd like to see how they got around the starter mounting issue. On all the bikes I've seen, the starter is mounted to the transmission, so they either had to build a mounting bracket, or find an engine application that would work. I dont know of a harley engine that has the starter mounted direct. Has anybody seen one of these up close, and can shed some light on how it was done?
14' Dixon Warrior bateau w/ 13hp Honda Longtail
Thu Apr 21, 2011 2:13 pm
I remember looking at these Predator motors back in 2005 and I believe they had a frame designed just for the motor. If I remember correctly Beavertail claimed they used a NASCAR frame engineer to design and build the frame (tube chassis type thing). Considering that a stock 88ci Harley motor (smallest Harley I'm aware of) has between 50-60HP, I would be a little leery to stick a motor on a frame designed to handle around 30HP. JMHO. But anything is possible with a little skill and some parts. Heard this one from a fabricator, "If they can build it, so can you".
“Believe none of what you hear and half of what you see.”- Benjamin Franklin
"Advertisements contain the only truths to be relied on in a newspaper." -Thomas Jefferson
Thu Apr 21, 2011 2:23 pm
viewtopic.php?f=3&t=8011
Here you go I remeber this topic from a while back. Hope it helps with some of your questions.
17*38 Klibert 23GDLT
Thu Apr 21, 2011 3:39 pm
autogateman.... the boat im talkin about was the one that was the only longtail out there this last weekend. we are tryin to get some more speed out of that boat!
Thu Apr 21, 2011 8:39 pm
ahh ok i remember. if it were me, id jus try and sell your motor and get an sd. or if youre stuck on keepin the lt, buy a 31 or a 35hp block and out it on there. there would be an incredible amount of work to be done to put a harley engine on a mm. the cylinders have to have something to support the top of them, thats why motorcycles have a top motor mount. the torque can literally push the two cylinders apart. thats why the beavertail predator has that racecar lookin frame around it. you could also do like i did an buy an sd frame and out your engine on it. i came out waaaay cheaper!
Thu Apr 21, 2011 9:10 pm
Should'nt be that hard of a build if you have access to the fab and machining equipment. I have a VW motor mounted on a home made longtail frame. I cut the bell housing off of a VW transaxle to have a starter mount. Maybe you could do something similar for the Harley motor
Fri Apr 22, 2011 3:28 pm
I have looked everywhere for a frame and no luck. where did you find yours autogateman I have 27 koeler and it would look great on a gdsd frame.
Fri Apr 22, 2011 3:34 pm
